Fire wall?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Fire wall?
Page: [1]
Login
Fire wall? - 6/25/2007 8:15:02 PM
Dave trimmer
Status: offline
for my spad I need a new firewall. I'm making one out of wood. What should I cover the wood with to prevent fuel soaking?
Thanks, dave trimmer
_____________________________
a minute of perfection was worth the effort. A moment was the most you could ever expect from perfection. - chuck Palahniuk
       Post #: 1
RE: Fire wall? - 6/25/2007 9:44:23 PM
Villa
Status: online
I use 30 minute epoxy.
(in reply to Dave trimmer)
       Post #: 2
RE: Fire wall? - 6/25/2007 9:49:59 PM
Mike in DC
Status: offline
The best stuff to fuel-proof the wood is an epoxy resin specifically made to use as a "paint". You will find many people who suggest thinning regular epoxy with alcohol or other solvents, but I have never found that satisfactory. You used to be able to get epoxy resin at Home Depot, but I haven't seen it lately. I've heard that polyester resin (used to soak fiberglass for boats and similar) is fuel proof as well (and you can get it at Home Depot) but I haven't tried it myself. TopFlite makes an aerosol paint that is fuel proof.
The problem with any of these methods is that you have to buy a whole lot more paint than you need, so it's expensive. For the same cost of the paint, you could buy a polyethylene cutting board that will make dozens of firewalls and not need to be fuel proofed.
       Post #: 3
RE: Fire wall? - 6/25/2007 11:31:13 PM
Clean
Status: offline
Just mix 30 minute epoxy and thin it with either alcohol or acetone. If you use alcohol try to use 91% to keep the water down. You can use acetone as well if you have it and who doesn't?
There's is really no need to guild the lily, if you have the resin, use it. I've never had it, so I've never used anything but the epoxy, and I've used a whole bunch of it.
Of course, if you can get down to Walmart and pickup a cutting board, your fuelproofing problems will be over.
From Somewhere near Parkville, Mo.
William Crane (aka Mr Clean) Rever Brother #168 Time Man of the Year
(in reply to Mike in DC)
       Post #: 4
RE: Fire wall? - 6/26/2007 6:33:19 AM
Hossfly
Status: offline
15 to 30 min epoxy is fine. Thin if you wish, however if you spread some out and then use your heat-gun on the epoxy, it will go Gin-Thin and run well plus soak right into the wood. Brush it around as you wish and you will get a very long lasting firewall.
I have a Spad "40" with a ST 61 ABC that I kamikazed a Pylon Pole with just yesterday. Broke some points in the fuse. (all fixed now) and wrinkled one side of the wing. Firewall is still good to go, and so is the plane. No big dents so should be ready to go finish off that P.Pole on Wed.
Horrace Cain. AMA Life L-93, Leader and CD for 45 years
Christian TEXAN American Heterosexual PRO-GUN Conservative: Any Questions?
       Post #: 5
RE: Fire wall? - 6/27/2007 6:30:35 AM
n8wvp
Status: offline
quote:
ORIGINAL: Dave trimmer
my landlord is a sail boater, i have been useing up his left over spar varnish on firewalls, repairs to balsa sidewalls,talls,rudders. two coats and i don't recover with anything. when your done flying, spray with simple green,or something simular,wipe down, put away. steve.
       Post #: 6
RE: Fire wall? - 6/28/2007 12:45:46 AM
acam37
Status: offline
I usually don't fly my spads more than about 20 flights before I'm ready to build another one. Therefore I don't even worry about fuel proofing my firewall. Cleans suggestion of the HDPE cutting board is the best way to go. I think if you cut it right you can get about 10 to 12 firewalls.
(in reply to n8wvp)
       Post #: 7
RE: Fire wall? - 6/28/2007 12:52:23 AM
Tkeith9512
Status: offline
One small bottle of black Dope and some acid brushes will do dozens of firewalls and wing rubber band dowels.
Tom
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU5
