Rcpilot
Joined: 3/20/2002 From: Arvada, CO, USA Status: online
I wouldn't recommend using standard switches anymore. Not heavy enough. You need to look at using some heavy duty switches. Tower sells Hobbico heavy duty switches. Cermark sells JR heavy duty switches. Chief Aircraft sell them too. So does Troy Built Models. Hooking up dual batteries is simple: Each battery gets it's own switch. There is no pont in running 2 batteries on a Y harness and putting them both into the same switch. You just killed your redundancy. The batteries might be good--but if the switch fails--your done. Dead plane. So, run each batery on it's own switch. The receiver (RX) can be powered by plugging into ANY port. So, all you need to do is plug in all your servos and then plug each switch/battery into the left over ports. You'll be using 2 switches, so you'll need 2 open ports on the RX to plug into for power. That's a basic dual battery/switch setup. It will usually give extended flight times because we tend to use bigger batteries--or at least 2 of the same batteries that you would have used in the past. 6V systems drain down faster than 4.8V systems, but the 6V system also helps boost servo torque and speed. You also have a bit of safety factor built in because if one cell in a 6V pack drops out--you still have 4.8 to fly it back to the runway. If you loose a cell on a 4.8V pack, your down to 3.6V--your done. Dead plane. If your building a BIG plane and your going to run lots of digital servos, it starts to get more complicated. Most guys flying 35% or bigger will at least consider some type of power distribution system. Powerboxes. Not every guy uses powerboxes or believes in them. It's just a choice you have to make. I've seen guys fly a 35% plane with a 100cc engine on 2 regular batteries and 2 switches, just as I described above. These planes are mostly intended for IMAC and aren't subjected to the harsh power demands that a 3D flyer will put on plane. Gentle flying with smooth inputs and low control surface movement is the norm in IMAC. 2 heavy duty bateries and switches will do the job. If your going to build a 3D monster then you probably want to look at a more robust power system.
_____________________________
Airplanes have expiration dates. It''s just not printed anywhere on them. I''m not really an airplane pilot; but I did stay at a Holiday Inn Express last night.
