How to make a 3D American Flag on your planes
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
DAB-A-GLUE Pro-Builder Glue Applicators
Seller:  donnboyd
Details:   $3.95   |  6/18/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Tips & Techniques >> How to make a 3D American Flag on your planes
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
How to make a 3D American Flag on your planes - 3/6/2003 2:57 AM
TERMAGATOR
Score: 100
Last Login: 8/12/2006
Status: offline
This is my 4th flag I'v done, all have been done on profiles.....the types of covering in this series are:
White Ultracote for my base/back ground
Grey, transparent red and transparent blue monokote .
I applied the all monokote useing windex...I do use heat around some edges as you will see in these pics....Total time was maybe 6 hrs...I kinda rushed it. alot of these steps work best if you let them sit overnight.......here we go
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
drawing the grey stips - 3/6/2003 2:59 AM
TERMAGATOR
Score: 100
Status: offline
after you have your model covered white , its time to start laying down the gray monokote . These lines are just random, nothing has to be defined, I like for the 1st few to go from the LE to TE but they dont have to
Click for fullsize
< Message edited by termagator -- Mar 5 2003 10:06PM >
Hide Signatures
(in reply to TERMAGATOR)
       Post #: 2
more grey - 3/6/2003 3:00 AM
TERMAGATOR
Score: 100
Status: offline
heres one layed out on the wing
Click for fullsize
Hide Signatures
       Post #: 3
windex - 3/6/2003 3:02 AM
TERMAGATOR
Score: 100
Status: offline
apply a light coating of windex, and then lay your coveing in the windex and position it where you want
Click for fullsize
Hide Signatures
       Post #: 4
credit card - 3/6/2003 3:03 AM
TERMAGATOR
Score: 100
Status: offline
use an old credit card to squeegie the windex out from under the grey, and wipe up excess Windex with a paper towel
Click for fullsize
Hide Signatures
       Post #: 5
all the grey - 3/6/2003 3:05 AM
TERMAGATOR
Score: 100
Status: offline
Here what it looks like with all the grey(shadow) in place...hey this looks kinda neat by it self
Click for fullsize
Hide Signatures
       Post #: 6
transparent blue - 3/6/2003 3:08 AM
TERMAGATOR
Score: 100
Status: offline
now after you have the grey down, draw the outline of the blue box with the stars. I like to use water soluable flair felt tips for monokote jobs
Click for fullsize
Hide Signatures
       Post #: 7
transparent blue - 3/6/2003 3:10 AM
TERMAGATOR
Score: 100
Status: offline
now lay a peice bigger than the area you drew on the wing over the wing, you can look thru the covering and trace where your blue box will be on the wing.....I screwed up here and didnt cut a peice of monokote big enough so I had to use 2 peices of trans blue, but thats OK...I was running low on trans red too
Click for fullsize
Hide Signatures
       Post #: 8
extra blue - 3/6/2003 3:12 AM
TERMAGATOR
Score: 100
Status: offline
heres the peice of blue that I added,
make sure you cut it where it hangs over the LE and the tip
Click for fullsize
< Message edited by termagator -- Mar 5 2003 10:19PM >
Hide Signatures
       Post #: 9
blue box - 3/6/2003 3:13 AM
TERMAGATOR
Score: 100
Status: offline
Heres the blue box temperarely layed down
Click for fullsize
Hide Signatures
       Post #: 10
stars - 3/6/2003 3:15 AM
TERMAGATOR
Score: 100
Status: offline
this is probably the most difficult process, drawing and cutting out the stars....these stars are not symetrical...there just draw on and I tried to keep them close to the same size...it doenst matter if some are biger or not perfect...remember the flag is suppose to look like its got some depth
Click for fullsize
Hide Signatures
       Post #: 11
applying the stars - 3/6/2003 3:18 AM
TERMAGATOR
Score: 100
Status: offline
after you cut out all the stars, apply Windex to the wing and lay your blue box down, again squeegie the windew out form underneath the blue, be careful some of the tips of the stars may catch the edge of the credit card. make sure you got plenty of blue covering hanging off the LE and wing tips
Click for fullsize
Hide Signatures
       Post #: 12
red stripes - 3/6/2003 3:21 AM
TERMAGATOR
Score: 100
Status: offline
now after that has set a while,(best results overnight), start at the bottom right hand corner of your blue box, and start drawing your red lines. I make my lines break in a different direction when they touch the grey
Click for fullsize
< Message edited by termagator -- Mar 5 2003 10:34PM >
Hide Signatures
       Post #: 13
red - 3/6/2003 3:23 AM
TERMAGATOR
Score: 100
Status: offline
then again ike I did with the blue, take a peice of trans red and lay it over the lines you just drew on the wing and trace those lines to your red covering , then remove and cut it out
Click for fullsize
Hide Signatures
       Post #: 14
red strips - 3/6/2003 3:24 AM
TERMAGATOR
Score: 100
Status: offline
here it is layed in place and cut to fit
Click for fullsize
Hide Signatures
       Post #: 15
continue red - 3/6/2003 3:26 AM
TERMAGATOR
Score: 100
Status: offline
now just continue to draw the red line, remember to change the direction slightly when it touchs the gray
Click for fullsize
Hide Signatures
       Post #: 16
heat - 3/6/2003 3:28 AM
TERMAGATOR
Score: 100
Status: offline
since the ailerons and the gray had some time to sit...I pulled them off and heated the edges with the iron to seal them down
Click for fullsize
Hide Signatures
       Post #: 17
adding more strips - 3/6/2003 3:31 AM
TERMAGATOR
Score: 100
Status: offline
after I sealed the gray on the TE of the wing and the edges of the ailerons....i stuck the ailerons on again and stuck more red on with the same methods used earlier
Click for fullsize
Hide Signatures
       Post #: 18
red continued - 3/6/2003 3:33 AM
TERMAGATOR
Score: 100
Status: offline
I try to make my red stripes carry over on the other side of the fuse or ailerons so it looks like its the same stripe
Click for fullsize
Hide Signatures
       Post #: 19
red - 3/6/2003 3:36 AM
TERMAGATOR
Score: 100
Status: offline
Like I said I was running low on transparent red monokote so I had to peice some of this in, but a little red laying over alittle red makes a nice color change like the grey does to transparent red
Click for fullsize
Hide Signatures
       Post #: 20
heat around the edges - 3/6/2003 3:38 AM
TERMAGATOR
Score: 100
Status: offline
I use heat arond all hard surfaces like LE and TE
Click for fullsize
Hide Signatures
       Post #: 21
almost complete - 3/6/2003 3:42 AM
TERMAGATOR
Score: 100
Status: offline
Heres the final
after I use heat around all hard edges I come back over the open wing areas with some monokote trim solvent applied with a Q-Tip. this seals down all edges that dont have heat
good luck....would love to see other peoples flags.....The 1st time you try this it may seem difficult. but if you take your time and be patient...it will not be as bad.....also i was luck to keep the red stripes outta the hinge line. sometimes it dont alway work out that easy......Gator
Click for fullsize
Hide Signatures
       Post #: 22
How to make a 3D American Flag on your planes - 3/6/2003 3:53 AM
nascarfan88
Score: 100
Last Login: 10/1/2004
Status: offline
nice job termagator! I've got to give this a try on my next build. Wondering about wrinkles that appear - can they be heated and shrunk or how do you do it????
Hide Signatures
       Post #: 23
How to make a 3D American Flag on your planes - 3/6/2003 3:56 AM
PaulSwany
Score: 100
Last Login: 5/5/2009
Status: offline
Gator... That is soooo cool... I can't wait to do my Aeron with the flag... Maybe I'll do my next taco with the flag....
Hide Signatures
       Post #: 24
How to make a 3D American Flag on your planes - 3/6/2003 4:09 AM
nascarfan88
Score: 100
Status: offline
Ditto - I've got a CG Extra 300 with a white wing so the base is already there just add the flag. The top of the wing is red/orange/yellow starburst. Already pretty flashy.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.125RCU1
