How to make a 3D American Flag on your planes
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> How to make a 3D American Flag on your planes
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
How to make a 3D American Flag on your planes - 3/9/2003 10:47:34 PM
Cactus.
Status: offline
how about a Cornish flag which is black with a white + ?
the grey shadow wouldn't work
_____________________________
My half dead website www.philsrcworld.fsnet.co.uk new site coming soon.
Redruth & District model flying club www.rcflye
(in reply to TERMAGATOR)
       Post #: 51
How to make a 3D American Flag on your planes - 3/9/2003 11:45:48 PM
TERMAGATOR
Status: offline
Cornish?....you mean them "HENS".?....send me a pic, I might have an idea/substitute color for grey ....G
       Post #: 52
How to make a 3D American Flag on your planes - 3/10/2003 12:02:59 AM
Cactus.
Status: offline
Hens? you means them fings on der farm?
Click to see fullsize image.
Click for fullsize
       Post #: 53
How to make a 3D American Flag on your planes - 3/12/2003 9:31:50 AM
Rudeboy
Status: offline
Termagator,
Very nice job. Really cool.
I've got to give this one a try. Never heard of the Windex thing before, but if it works as good as you make it sound, I can't miss.
A couple of questions though:
1) Is that Windex stuff something special, or is it just your basic windscreen or window cleaner? The stuff I use to clean my planes is something like that and contains alcohol. Will that work ok?
2) How do you get the patterns to lay flat on a open rib structure, with the covering sagging between the ribs?
I've never spent much time on iron-on-covering airplane decoration, because of poor results... You might have changed my life...
       Post #: 54
How to make a 3D American Flag on your planes - 3/12/2003 10:00:07 AM
jneesy
Status: offline
im pretty sure it has to be an ammonia based cleaner
Hey y'all watch this
       Post #: 55
How to make a 3D American Flag on your planes - 3/12/2003 9:14:27 PM
TERMAGATOR
Status: offline
Rudeboy...I guarentee it will change your life.....Any soapy substance should work......I used to use soapy water, a mixture of tap water and dish washing detergent...I would have a large container of water, and poor liquid dish washing detergent in and stir it real slow, so as not to make any bubbles. I switched over to windex because of one, its in a nice spraybottle and 2 , I didnt have to have the large container anymore.
The 2nd part of your question, if were talking you have a base coat of covering down over the ribs, its no problem to add trim peices, the soapy water will allow you to place them on the base covering, move them around to where you want it, and then just squeegy out the soapy water,
Remember this windex method does not work on regular ultracote,,,I'm told it will work with Ultracote Plus,,but I have never tried it...Windex does work with most other covering ie 21st century, Econocote, towercote.....Good luck with your project....Gator
       Post #: 56
Bummer - 3/13/2003 6:32:59 AM
Rudeboy
Status: offline
I just tried a test piece on my wing... it was a no go...
I'm using Oracover... I don't know if you guys over in the states know this stuff?
For me it is the best covering material I have ever used... but apperantly not for this application!
I think I have some old leftovers from Solarfilm somewhere in the basement... I might give that a try tommorow to see if it works.
And I even used my brand new VISA card... I was thinking: "Only new equipment for this plane!"
What card are you using?
       Post #: 57
Re: Bummer - 3/13/2003 8:16:41 AM
TERMAGATOR
Status: offline
[QUOTE]Originally posted by Rudeboy
[/QUOTE]
There is no substitute...I use American Express..."never cover a plane without it"
I never tried it with oracover,,,I have never used it either....If your puting it on a plane thats been flown...I always try to wipe them down with alcohol, just to get the oil off....Can you get monokote?,,,sorry to here it didnt work for you on the 1st time...Gator
       Post #: 58
How to make a 3D American Flag on your planes - 3/13/2003 9:06:57 AM
Rudeboy
Status: offline
I wiped the area where I tried the test piece clean with alcohol, even though the plane has not yet flown... just to get all those nasty finger prints off.
I don't know about the monokote... will have look into that and call around a little.
I'm determined to make this work... it looks just too beautiful to pass...
My guess is that I need a covering material of which the glue film dissolves a little when it comes in contact with the detergent in the window cleaner.
       Post #: 59
How to make a 3D American Flag on your planes - 3/13/2003 9:13:49 AM
TERMAGATOR
Status: offline
maybe it is a combo of the backing and the soap...try this,,,stick a peice of covering on the wing with windex, use the credit card. let it sit overnight,,,,,let me know if this works. Ultracote, will lay down like its gonna stick, but then curls up after the windex evaporates.....is this what happened to you?...Gator
       Post #: 60
How to make a 3D American Flag on your planes - 3/13/2003 9:36:05 AM
Rudeboy
Status: offline
Even worse...
It curled up while still wet...
I cleaned the wing, sprayed it with my window cleaner, put on a piece of covering, thouroughly went over it with the creditcard... and saw it curl back up after about 5 seconds...
Does Monokote have a combined glue-adhesive backing? I mean, is the colour of the covering also the glue? Oracover is a coloured film with a separate glue layer.
I know Solarfilm has a combined backing, because when you're doing edge, the colour sticks to your covering iron...
Heck, I'll just test the Solarfilm and see how it works, instead of typing messages on the computer...
       Post #: 61
How to make a 3D American Flag on your planes - 3/13/2003 3:32:56 PM
Cactus.
Status: offline
i guess i stumped you on a black flag hey Gator
Think all i can do is make the outline wavy and the same with the cross. Tho i have no plane i can do that with yet
       Post #: 62
How to make a 3D American Flag on your planes - 3/13/2003 5:05:07 PM
nashtm
Status: offline
Hey Gator now you have really started something - I have decided that the red stripes on my Super Chipmunk wing have to have some depth. I am going to give them a dark shadow and torn ends.
Thanks for the inspiration
       Post #: 63
How to make a 3D American Flag on your planes - 3/13/2003 8:47:21 PM
TERMAGATOR
Status: offline
nashtm,,,glad i could help,
Phillybaby......I doubt I get a chance to do it today but i think you could still make that cornish flag at least look like its moveing....I think you could put the gray on last, on top of everything, it would kinda look like light reflecting off black (if thats possible)...you could just make you white hoizontail line wavey, same with the vertical...if I was home now i could do one real fast, but I'm at work and whenI get off I'm going to houston Tx. Be back tue, may try and help you out then
rudeboy, monokote has a clear backing that is pulled off, it not tacky, you are able to move it around on what your covering easily. With some colors its hard to tell which side has the heat sensative backing(one side looks dull) when you lay monokote over monokote sometimes it moves easily, other times it may try to static like cling to the other (base) covering,,,but the windex eliminates the staticy cling, makes it easy to position..Gator
       Post #: 64
How to make a 3D American Flag on your planes - 3/13/2003 10:06:57 PM
Cactus.
Status: offline
im away till end of march, dont fret too much mate
       Post #: 65
How to make a 3D American Flag on your planes - 3/13/2003 10:23:35 PM
stall
Status: offline
I would like to see an example of the torn look. Can someone post a pic of something?
I'm impressed with what I have seen.... wow
       Post #: 66
