How to make a 3D American Flag on your planes
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> How to make a 3D American Flag on your planes
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
How to make a 3D American Flag on your planes - 4/23/2003 5:40:12 PM
Goinstraightup
Status: offline
nashtm is correct. Often when you buy Ultracote is has Oracover printed on the edges.
(in reply to TERMAGATOR)
       Post #: 126
How to make a 3D American Flag on your planes - 4/23/2003 6:21:46 PM
Texas 3D
Status: offline
[QUOTE]Originally posted by Texas 3D
I am no Gator, but I know the answer to this one also : Yes it will ! [/QUOTE]
oops.... I was wrong. Sorry. I didn't read the questions right. I thought he ment Monokote over Ultracote. Ultracote will not accept the windex or soapy water method. Actually I use just water with a couple of drops of dish soap in a spray bottle.
It doesn't matter if it is windex or not. The windex doesn't do anything. It is just used to be able to slide the monokote around on the surface. Therefore the water & soap will work as well. I even use this method to apply all my decals. No more bubbles on large decals.
_____________________________
Ulf
       Post #: 127
How to make a 3D American Flag on your planes - 4/23/2003 6:32:10 PM
TERMAGATOR
Status: offline
Salmonbug. you can also use soapy water...I use't to take liquid dishwashing detergent, and a large bowl of water, stir in the detergent so as not to make bubbles, stick you finger in the water after you stir in the saop, rub you finger together...if the water feels oily then your ready...works same way, peel backing, put the entire peice in the covering, then place it on your surface, and squeegy out the saopy water...let sit overnight and come back when you finish the model and do the Q-Tip in acetone around edges...Good Luck..Gator
       Post #: 128
How to make a 3D American Flag on your planes - 4/23/2003 8:03:29 PM
Goinstraightup
Status: offline
Does anyone know if the Windex method works on the Neon colors of Monokote? I noticed that the Neon colors have a white backing before the adhesive. Does that have any affect?
       Post #: 129
Works with neon - 4/23/2003 8:14:01 PM
PaulSwany
Status: offline
Yup... windex works with the monokote Neon colors.... I used that method on my SuDoKhoi....
Click to see fullsize image.
Click for fullsize
       Post #: 130
How to make a 3D American Flag on your planes - 4/23/2003 10:55:49 PM
Goinstraightup
Status: offline
Thanks Paul Looks great!
       Post #: 131
How to make a 3D American Flag on your planes - 4/23/2003 11:02:14 PM
SALMONBUG
Status: offline
as I understood, I will have to find monokote.....
In case of positive climb, gear up !!!
       Post #: 132
How to make a 3D American Flag on your planes - 4/23/2003 11:33:30 PM
TERMAGATOR
Status: offline
works with soapy water/ windex:
monokote
towerkote
21st century film
econokote
Black Baron film
there are probably more, this is what I have had success with....G
       Post #: 133
How to make a 3D American Flag on your planes - 4/24/2003 9:18:43 AM
JohnnyV44
Status: offline
Great Post Termigator .......Can't wait to see your Checkerboard...
You should do a "How To book" as someone else mentioned...
I'm betting it would do pretty good for you....
Thanks again
Ex
       Post #: 134
How to make a 3D American Flag on your planes - 4/24/2003 9:23:17 AM
TERMAGATOR
Status: offline
ExCaliber, I did a flowing checkerboard thread in the tips section, its not as elaborate as the flag , check it out....G
       Post #: 135
Hey guys, what am I missing here??? - 4/24/2003 2:18:56 PM
Capt Jim
Status: offline
Experimenting with several mfrs covering material, windex did allow sliding the trim piece easily, however, it failed to activate the heat sensitive glue and therefore no bonding was achieved; merely a static cling. Using acetone to seal the edges failed, as it disolved the glue and the color and it went so far as to attack the film itself causing it to deform somewhat. Acetone is a very aggressive solvent, so it does not surprise me to see it ruin the film. I wonder what the active ingredient is in the film mfrs liquid glue activator? Any new suggestions?
Thanks for a great thread, and wonderful new ideas for entertaining covering schemes. It has made me want to try some of these tricks. Thanks 'Gator.
Captain Jim
       Post #: 136
How to make a 3D American Flag on your planes - 4/24/2003 2:55:36 PM
SALMONBUG
Status: offline
my experience show me that acetone doesn't attack oracover
in fact this is a great thread with plenty of very usefull advises from the uncontested ironing master gator
       Post #: 137
How to make a 3D American Flag on your planes - 4/24/2003 6:41:53 PM
TERMAGATOR
Status: offline
If static cling is all thats holding the covering on, then thats enough. If the acetone is eating the film try the trim solvent, it is kinda expensive and stinks though.....another option to try would take the tip of the iron and go around edges(low temp)....good luck
       Post #: 138
How to make a 3D American Flag on your planes - 4/24/2003 6:56:12 PM
Capt Jim
Status: offline
The iron definately works, but you have to be sooooo careful to avoid the dreaded "blisters". (air bubbles trapped between the layers of film). I'm gonna try some of the mfrs trim solvent...maybe we can figure out what it is, and save a bunch of money using the generic product. Let me know if you have any luck in telling what its made of.
On a related subject, I have some non heat shring film, made by 3M, for signs, boat graphics, etc. Its a nice metalic film, and it is actually reflective like a stop sign, and its cool to see it change its shade of color as the light hits it at odd angles. I'm going to try it for trim strips, but since it is metalic, the warning is that if you covered the entire plane with it, you'd have to lead the antenna out of the fuse, because the metalic would act as a shield ,and reduce the range. But it looks soooo cool.
jim
Captain Jim
       Post #: 139
How to make a 3D American Flag on your planes - 4/24/2003 8:24:42 PM
TERMAGATOR
Status: offline
lets see some pics when ya can Capt Jim....G
       Post #: 140
My first flag - 5/3/2003 8:53:55 AM
Xavier Mouraux
Status: offline
Thanks a lot Gator for all the info on the flag and the shadow in particular. I was looking to learn about that for a while and your posts have convinced me to try it. I got the grey and the transparent color this afternoon and did the flag tonight.
I choose an easy one first to try under the wing of my back up Cap 232 25%. The next one will be the Canadian flag on my pattern plane.
Xavier
Click for fullsize
xavier.mouraux.com
       Post #: 141
First Attempt - 5/3/2003 1:45:43 PM
Bananaskin
Status: offline
Well,
Here goes, this is the first attempt at covering the upper surface of the wing with gator's instructions :
Click for fullsize
