RE: How to make a 3D <span class=
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> RE: How to make a 3D <span class= Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: How to make a 3D <span class= - 1/23/2004 12:20:58 AM
Mike Bogh
Status: offline
SBBTTT...Shameless Bump to the Top
_____________________________
Best to you all,
Mike
In memorium
Art Grabow Sr. AKA Grnbrt..RIP mah Brother
(in reply to TERMAGATOR)
       Post #: 201
RE: RE: How to make a 3D <span class= - 1/26/2004 2:50:01 AM
Balsa Master
Status: offline
it very good info and if some one wanted it it would be a very simple matter to go to that little text box that says "Search" right next to it there and look for it. i myself learned a great deal from this post but still, it was dead for a month. bty you feel like covering my planes for me gator?
quote:
Live your life in such a way that the Preacher doesn't have to lie at your funeral.
he he, i like that
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Balsa Master -- 1/25/2004 9:50:14 PM >
fly hard, crash hard... or don't fly at all!
(in reply to Mike Bogh)
       Post #: 202
RE: How to make a 3D American Flag on your planes - 1/26/2004 6:42:36 PM
csdawggie
Status: offline
Here is my attempt at this. Only problem I had was the trim solvent ate the edges of the monocote.
Click for fullsize
       Post #: 203
RE: RE: How to make a 3D <span class= - 1/26/2004 6:53:32 PM
Balsa Master
Status: offline
use windex...
(in reply to csdawggie)
       Post #: 204
RE: RE: How to make a 3D <span class= - 1/26/2004 7:13:01 PM
PigMan Buggerus
Status: offline
Has anyone tried the no-heat trim solvent from Sonic Tronics, or is this the same stuff as the MonKote trim solvent?
Allan
The Voice of the Angry!
http://www.voxirati.com
(in reply to Balsa Master)
       Post #: 205
RE: RE: How to make a 3D <span class= - 1/26/2004 7:16:47 PM
csdawggie
Status: offline
I used windex (well 409) on all of it but was trying the trim solvent on the edges.
(in reply to PigMan Buggerus)
       Post #: 206
RE: RE: How to make a 3D <span class= - 1/26/2004 7:35:42 PM
PigMan Buggerus
Status: offline
As a follow up, if anyone has tried the sonic tronicsstuff, will it work on Ultracoat?
Allan
       Post #: 207
RE: RE: How to make a 3D <span class= - 1/26/2004 8:28:00 PM
TERMAGATOR
Status: offline
nice job CSdawggie, I like it when the trim solvent disloves the edges, lets me know that its gett'n to the covering.
Pigman,,,,never heard of the sonic tronic stuff, I'd like to try some...G
       Post #: 208
RE: RE: How to make a 3D <span class= - 1/26/2004 9:01:40 PM
csdawggie
Status: offline
Thanks. The rest of the plane is maroon and the moving surfaces are chrome. I am planning to put some sort of Mississippi State symbol on the top of the wing
       Post #: 209
RE: RE: How to make a 3D <span class= - 1/26/2004 11:20:40 PM
Mike in DC
Status: offline
quote:
ORIGINAL: PigMan Buggerus
I have used No Heat from LDS, maybe it's the same stuff you're referring to.
Anyway, it is NOT the same stuff as MonoKote trim solvent, although it works about the same for a lot of applications. The reason I know it's not the same stuff is I tried to follow Ann Marie's instructions for doing trim on the MonoKote site, and it didn't work. She says to let the trim solvent evaporate before you put the trim on. With MonoKote trim solvent, that works, because it leaves other chemicals on the surface. With No Heat, if you let it evaporate, it's gone, leaving nothing to stick the trim on.
But otherwise, it works fine, and I used it for years without realizing the difference.
       Post #: 210
RE: RE: How to make a 3D <span class= - 1/27/2004 12:10:43 AM
PigMan Buggerus
Status: offline
Mike,
Did you ever try it with Ultra Coat?
Allan
(in reply to Mike in DC)
       Post #: 211
RE: How to make a 3D American Flag on your planes - 1/27/2004 1:48:23 AM
tedster
Status: offline
I finally got around to building my upraor and figured, what the hell why not! With my wifes keen eye for the artsy stuff, here is my feable attempt at the flag design. click on the links for a full view.
Click for fullsize
Click for fullsize
< Message edited by tedster -- 1/26/2004 7:47:07 PM >
TIA, Ted
       Post #: 212
RE: RE: RE: How to make a 3D <span class= - 1/27/2004 2:05:29 PM
Balsa Master
Status: offline
eh, looks better than mine. i really should start using a heat gun, but it takes so long... i dun no why, it either wont shrink or it burns it. thats y i use my good old 13$ iron
(in reply to tedster)
       Post #: 213
RE: RE: RE: How to make a 3D <span class= - 1/27/2004 8:59:20 PM
TERMAGATOR
Status: offline
Nice Job Tedster
       Post #: 214
RE: RE: RE: How to make a 3D <span class= - 1/27/2004 9:02:14 PM
tedster
Status: offline
this was all done with windex and trim solvent.
TIA, Ted
       Post #: 215
RE: RE: RE: How to make a 3D <span class= - 1/30/2004 4:54:56 AM
Balsa Master
Status: offline
i may need to get some of this trim solvent, never used it b4... then again, this is my first time laying mono over mono so i guess theres a reason for that. still looks good though.
yay 800 posts
< Message edited by Balsa Master -- 1/29/2004 11:53:37 PM >
       Post #: 216
RE: RE: RE: How to make a 3D <span class= - 1/30/2004 1:40:01 PM
TERMAGATOR
Status: offline
quote:
ORIGINAL: Balsa Master
yay 800 posts
acetone works also as a trim solvent...g
