Mike Connor
Joined: 1/10/2002 From: Tulsa, OK, USA Status: offline
quote:
ORIGINAL: iron eagel I plan to sheath it and skin the sheathing with carbon fiber veil (tissue) that weighs .2 oz per sq yrd. ...I probably will not even do the maiden on it but have one of our speed guys do that, I have get to work to flying something really fast before I would feel comfortable going over 150 anyhow....It may well result in just finding out what the Vne is for the airframe, or what happens when a prop tip exceeds mach1, but looks like it might be able to exceed 220 at the very least. ....one of my favorites is something called the Alantica that is being pursued by the guy who use to make wings for the Velocity FS airplane. Paul, .2 oz per sq yrd is light. Is it flexible or fairly rigid? It may take a few flights but you should do fine with speeds of 150 mph. Not sure about 200+ though as I have not experienced that yet. To me the airframe is not much harder to see, because of size, then my Q-500, F1 and other 40 size airframes. I suspect that Vne is up to the builder and you and Speedy are well above average builders and understand some of the problems you could face. That "Alantica" looks neat and I like the winglets. What is the size of the battery you will be using? Just wondering how it will fit in the fuse.
_____________________________
Mike http://www.mikesrc.us/
