RE: (Something Fast?) Delta Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: (Something Fast?) Delta Build Thread Page: <<   < prev  13 14 15 [16] 17 18 19 20 21 22   next >   >>
Login
RE: (Something Fast?) Delta Build Thread - 5/16/2008 2:04:18 AM
evan-RCU
Status: offline
I'll be in Tulsa next week, when there I'm at Mingo where it goes under hwy64...
_____________________________
Revver #125, Pico Owners Club #3
R/C Anonymous. My name is Evan and I have not flown for 14 hours.
(in reply to Mike Connor)
       Post #: 376
RE: (Something Fast?) Delta Build Thread - 5/16/2008 8:05:55 AM
Mike Connor
Status: offline
quote:
ORIGINAL: evan-RCU
I used to work very close to that area years ago. I live closer to down town.
Mike
http://www.mikesrc.us/
(in reply to evan-RCU)
       Post #: 377
RE: (Something Fast?) Delta Build Thread - 5/18/2008 4:00:17 PM
FASTCRASHER
Status: offline
hey guys i started workn on my screamin demon 2day!!!
in 2 hrs im this far ...wow it looks great !!
what do u guys thank
[image][/image]
Click to see fullsize image.
Click for fullsize
Click for fullsize
FASTCRASHER: REVVER BRO#.221
FLYEM FAST- CRASHEM HARD!!!!
       Post #: 378
RE: (Something Fast?) Delta Build Thread - 5/18/2008 4:56:11 PM
evan-RCU
Status: offline
Did you sell the last of the kits Mike?
(in reply to FASTCRASHER)
       Post #: 379
RE: (Something Fast?) Delta Build Thread - 5/18/2008 7:08:01 PM
Mike Connor
Status: offline
quote:
ORIGINAL: evan-RCU
Going through all my parts I was able to come up with a couple of excellent complete kits.
Also two complete kits with slight blemishes (one sold I think and will discount the other).
There is also one short kit with blemishes and only digital plans and manual (cheap).
May have a couple sets of CF spars if a scratch builder is interested. - .295 OD, .245 ID x 27 3/4" and 15 7/8" long. (Light and stiff arrow shafts)
Manual will remain available for download on my site and PDF plans are free if you ask.
Mike
       Post #: 380
RE: (Something Fast?) Delta Build Thread - 5/18/2008 7:23:15 PM
Mike Connor
Status: offline
quote:
ORIGINAL: FASTCRASHER
I think the winglets would look good mounted in the area you have them. I would however probably glue a tap to the bottom, glue the front piece on and have the entire area above the airframe sheeting. The winglet area is less then the regular vertical fins and my delta has not been flight tested with less vertical fin area then the winglets are. 1/4" tri stock at the base would make them strong.
Keep going and you will have it in the air soon. It will be quick with that engine.
Mike
       Post #: 381
RE: (Something Fast?) Delta Build Thread - 5/19/2008 3:05:23 AM
gooseF22
Status: offline
I used the winglets as they were shaped except I cut the tabs off the bottom. thougght the extra stability would be necessary for the torque the little electric produces. it torqued my bobcat very bad. can always cut em down later or sweep em a little.
I did get the belly glassed yesterday and the winglets hysol'd on. the wood part is complete and will be beefing it up and final sanding. working on it as best Ican. I really want to fly it.
Goose
Team Fromeco
       Post #: 382
RE: (Something Fast?) Delta Build Thread - 5/19/2008 3:16:18 AM
Mike Connor
Status: offline
quote:
ORIGINAL: gooseF22
Goose, I think your kit was before I included both the laser cut winglets and vertical fins. The winglets did not have the tab on the bottom and had more sweep. You should be able to sweep your vertical fins some with out any negative effects.
I really want you to fly it so stay after it when you can.
Mike
(in reply to gooseF22)
       Post #: 383
RE: (Something Fast?) Delta Build Thread - 5/20/2008 7:44:50 AM
FASTCRASHER
Status: offline
HEY MIKE ...
HERE IS SOME NEW PICS OF MY PROGRESS....
FIRST SHOT WAS 2 B SO U COULD SEE HOW CLEAN THIS CRAFT IS GOING TO B!
SECOND ONE IS TO SHOW THE FINS I CUT 1INCH OFF TO GEVE THEM MORE A SLANT,AND ALSO HOW I GAVE THE CABIN A AIRFOIL
3RD IS FULL BODY SHOT U CAN SEE WERE IM PUTING THE FINS AND 4TH IS I USED 1/2 INCH TRIANGLE STOCK TO MAKE THE ENDS ..SO LIGHTER AND LITTLE SMALLER WING !
TOOK UR ADAVICE AND MADE PLY TABS ON THE FINS
[image][/image]
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by FASTCRASHER -- 5/20/2008 7:46:21 AM >
       Post #: 384
RE: (Something Fast?) Delta Build Thread - 5/20/2008 7:58:41 AM
Razor-RCU
Status: offline
I guess you did not have an APC to put on for the pictures? LOL
Looks great man! Keep us posted...
Revver #5
       Post #: 385
RE: (Something Fast?) Delta Build Thread - 5/20/2008 3:33:59 PM
Mike Connor
Status: offline
HEY MIKE ...
That looks great and your progress is quick. I really like the way you did the fuse and tank area Plus the vertical fins look really good there. I bet it will be as fast as it looks, with the right prop.
Shipping another one today. Still have a couple left. Minor blemish = save money.
Mike
       Post #: 386
RE: (Something Fast?) Delta Build Thread - 5/23/2008 7:24:38 AM
FASTCRASHER
Status: offline
HEY GOOSE...
U GOT UR PLANE DONE YET?
OR AT LEAST SOME PICS?
I JUST GLASSED THE BOTTOM OF MINE TODAY
GOING TO GLASS THE TOP TOMORROW.
LOL YEA GUYS IM OUT OF APC SPEED PROPS
I ALMOST ALWAYS USE 9X6 OR 9X7.5 SEEMS TO WORK FOR ME R THEY WHAT U WOULD USE??
< Message edited by FASTCRASHER -- 5/23/2008 7:35:58 AM >
       Post #: 387
RE: (Something Fast?) Delta Build Thread - 5/23/2008 3:10:10 PM
Mike Connor
Status: offline
A 9" prop works great on this airframe. Use what ever pitch makes your engine happy.
Mike
       Post #: 388
RE: (Something Fast?) Delta Build Thread - 5/24/2008 6:32:25 AM
gooseF22
Status: offline
6 x 5.5 but turning it 30K. we will see. Actual specs are 28-2500Kv medusa on 6S A123, and it loads to about 65amps and 14 volts.
I got the tails mounted on the wings and glassed the belly. flying my jet tomorrow, sorry, its sexier. I will get there...
side note related to power:
I got the new power system on the nitro bobcat .25. its the new 36mm medusa 1600 kv with 8 A123 cells. turning an 8x6 apc.
it came on full at 73 amps and 18 volts loaded, but the wires get warm, and it settled in at 68 amps and 17 volts. I think my wiring isn't heavy enough, but it will have to do for the testing.
It has more static thrust I think, and about the same speed. testing it tomorrow.
Goose
Team Fromeco
       Post #: 389
RE: (Something Fast?) Delta Build Thread - 5/24/2008 8:04:02 PM
Razor-RCU
Status: offline
I would run a 9x8 APC.
Revver #5
       Post #: 390
RE: (Something Fast?) Delta Build Thread - 5/25/2008 12:54:46 AM
