iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
Mike that four pounds of thrust is with an electric df unit. I bet 25 oversize with a 90 would do better than you think, the beauty of that is you can blend the engine right into the body. If you run a prop on that engine and can get it to spool up to the rated 20-22,000 rpm think of what an 8-10 pitch prop would give you for a top speed. Lets see 8 X 20,000 = 160,000 inches per minute.... Nice to hear your design went international, that is cool. I have done the same thing using carbon fiber for spars, it is amazing how much strength you can get from a small amount of structure. And the beauty of it is that it distributes all of the force throughout the structure so it can take a lot of abuse. Hey while your at it put together a kit for one of the blue states will ya, you know where we drive cahhs.
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
