RE: (Something Fast?) Delta Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: (Something Fast?) Delta Build Thread Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: (Something Fast?) Delta Build Thread - 7/23/2007 9:30:33 PM
ChuckL
Status: offline
Hey Mike got the kit today looks real good. I layed the cowling from my Phenom on the plans and it looks like it may work needs a little repair work but no big deal. My 60LX fire should work out nicely.
(in reply to Mike Connor)
       Post #: 101
RE: (Something Fast?) Delta Build Thread - 7/23/2007 9:45:51 PM
Mike Connor
Status: offline
quote:
ORIGINAL: ChuckL
If the Phenom cowl works it could save some time. I put a couple of extra sheets of balsa in yours for extending the tank area down. This one should look and fly really good.
_____________________________
Mike
http://www.mikesrc.us/
(in reply to ChuckL)
       Post #: 102
RE: (Something Fast?) Delta Build Thread - 7/23/2007 11:38:42 PM
iron eagel
Status: offline
Mike
I am going to build two versions...
One which is electric just to see what the result, the second I am going to try an OS 46 VX-DF that spins up to 28,000 rpm.
Cowled with a tuned pipe this ought to prove to be an interesting version.
If I get real ambitious blow up the plans and alike I may also try a ducted fan version with the dynamax 5.25 df driven by an OS 91 df.
< Message edited by iron eagel -- 7/23/2007 11:39:26 PM >
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
       Post #: 103
RE: (Something Fast?) Delta Build Thread - 7/24/2007 1:00:17 AM
Mike Connor
Status: offline
quote:
ORIGINAL: iron eagel
Mike
I am hoping the airframe is clean enough to take advantage of the small diameter high rpm df props. It couldn't be any worse then a Dust with a 7" prop clocked at 165 mph. Over time I plan to experiment with props down to a 8" diameter.
You got me thinking about rudders so I may have to work on that next. I think tilting the rudder servo so the linkage will go above the elevon linkage will work.
Attached are a few pictures of the electric motor mount. This one is set up for a motor up to 2" in diameter but it could be made wider. The mount could also be slid back to the firewall if needed for longer motors. This particular setup is using 1/2" balsa tri stock behind the mount for support and 1/4" in the other areas. I don't have much experience with electrics so does that look workable to you?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Mike
(in reply to iron eagel)
       Post #: 104
RE: (Something Fast?) Delta Build Thread - 7/24/2007 2:27:13 AM
iron eagel
Status: offline
If yo plan to go with anything that approaches 1000 watts or better you may want to also glass the back of your mount and tristock to the fuselage. Keep in mind 750 watts is a 1hp motor. Larger electric motors can produce a lot of torque, more torque than a glow engine of equal size. On the flip side they produce a lot less vibration than a glow motor will, so you don't have to worry as much about mass dampening of the vibration. One consideration is you need airflow though the brush less motor and good airflow over your ESC, electrics in this range produce a lot of heat.
I am going to extend the hatch and compartment back to just forward of the control surfaces, I want to leave a 1/4 inch high opening across the rear of the compartment as a cooling exit for mine. I am also going to do the engine mount similar to yours but drill a hole though the center of the firewall to allow airflow back through the fuselage and vent it in the rear.
Now as far as the rudder I am going to move the servo forward and up. By doing this I hope to be able to run to control rods off of each side of the servo out to rudders. Chuck Esh used a similar setup on his Starliner canard he used two carbon fiber rods with ball links at each end to drive the two angled fin rudders on his design.
Using electrics give me the advantage in of playing with the battery location in order to balance the airframe. Either way being an engineer we can't build anything without trying to improve it.
       Post #: 105
RE: (Something Fast?) Delta Build Thread - 7/24/2007 2:42:39 AM
ZeppelinIII
Status: offline
Mike,
Sorry for the confusion, I haven't updated my info here yet. I received the one that you shipped to NH.
Everything looks great. light ply a little squirrely, but I've never been able to get that stuff straight. It should straighten out on the spare. You asked for comments so here's one: The instructions were a nice touch, I wasn't expecting them. While they do a nice job laying out the steps, it would be easier to read, at least for me, if you broke up the long paragraphs into more shorter ones. Just a thought. Kit looks nice and all the materials looks to be excellent quality.
planning on putting in the 50SX with Macs muffler that came off my dust. Won't be as fast as the 60, but should be quick enough for now.
I have the ribs on the CF spars, a little more work to get everything square and then hit it with some CA...
Zep
       Post #: 106
RE: (Something Fast?) Delta Build Thread - 7/24/2007 4:20:14 AM
Mike Connor
Status: offline
Paul,
The pictures of the electric mount are sequence shots with the last picture showing all the tri stock in place. Actually there is no glue yet since I will have to move the mount back some after getting exact dimensions of the motor. And yes, I keep trying to forget about cooling for electric motors. Your thoughts sound good.
Mounting the servos behind the rear spar is an option even though it is getting a little thin back there. Looking forward to seeing pictures of your electric motor, battery and rudder setup.
Mike
       Post #: 107
RE: (Something Fast?) Delta Build Thread - 7/24/2007 4:37:26 AM
Mike Connor
Status: offline
Zep,
I am taking notes of peoples thoughts and will try to correct anything that will make things easier. Someone else asked if there was a top and bottom and the answer is no. Not until you add the wing tips, vertical fin support or hatch.
Finding lite ply, or even aircraft ply, over 22 inches long with no warp is tough. None of the distributors will guarantee straight plywood. My prototype was built with the worst of everything to make sure there would not be a problem. As the plans suggest, turn the ribs so they bow towards the center. The engine mount and spars will pretty much hold things in place but small adjustments may be needed at the trailing edge.
The 50 SX should pull it around nicely. My stock thunder tiger got a lot of people attention.
Mike
(in reply to ZeppelinIII)
       Post #: 108
RE: (Something Fast?) Delta Build Thread - 7/24/2007 5:36:34 AM
ChuckL
Status: offline
Mine is framed up to the point of the center section and sheeting super simple to build so far. Everything fits together real nice, I put a layer of CF on the top and bottom of the motor mount which is what I always do on a DD. I'll try to get some pictures not much time I'm in the middle of a remodel job on the kitchen also, so I'm just building on breaks.
       Post #: 109
RE: (Something Fast?) Delta Build Thread - 7/24/2007 1:02:58 PM
acr007
Status: offline
Mike
An E version of your plane sounds good.
I built an eversion of my IC delta but a smaller version.
Span 27"
Chord 22"
2 * Hitech MG81's
Mega 16/15/3
4.1*4.1 prop
2 * 2S1P 2500 20c lipos flight power.
Top speed about 150 it is fast and light. A couple of pics.
Plesae build the e version would like to see how it turns out.
Click for fullsize
Click for fullsize
Click for fullsize
Revvers botherhood #70
ACR007
       Post #: 110
RE: (Something Fast?) Delta Build Thread - 7/24/2007 4:10:02 PM
Mike Connor
Status: offline
quote:
ORIGINAL: acr007
I am looking at the best way to build an E-Demon but it may be awhile before that project gets my full attention. Paul (iron eagel) will probably be first with electric.
I have an idea! you could order one and make it electric.
Mike
(in reply to acr007)
       Post #: 111
RE: (Something Fast?) Delta Build Thread - 7/27/2007 3:24:36 AM
ChuckL
Status: offline
I haven't had much time to work on this but here is what I have so far. Jett 60LX, Jet 6oz short tank, HS5625s all mounted will build bottom and top hatch around them now that they are all mounted.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 112
RE: (Something Fast?) Delta Build Thread - 7/27/2007 4:47:41 AM
iron eagel
Status: offline
Looks like it will fly as it sits. lol
Mike was looking for a record breaker, we may be seeing one come to be here!
       Post #: 113
RE: (Something Fast?) Delta Build Thread - 7/27/2007 5:31:59 AM
Mike Connor
Status: offline
I am really excited about this one as it will be a record breaker for a Screamin Demon. This FIRE setup will really look good when finished. There is one more 60LX being built but I am not sure if it is a FIRE and I have not received a progress report. A side exhaust sure is easy but the FIRE looks too good. I wish I could be there for the maiden with my video camera. My prototype will look pretty slow compared to this.
Mike
       Post #: 114
RE: (Something Fast?) Delta Build Thread - 7/27/2007 3:10:28 PM
