iron eagel
Joined: 7/15/2004 From: Middleboro, MA, USA Status: offline
Mike, I am still thinking about using rudders, the weight gain is one servo and linkage. Now for the reason for the mothership is twofold. First I am not going to use landing gear or retracts because of weight and drag. Second I don't want to burn up power taking off and given the amount of power heat is going to be an issue, the motor esc and batteries are going to be getting hot, and at these power levels even the wires are going to get hot. As the conductors and electronics get warmer you lose power to the prop. So my thought was it worked for the X-15 so why not try it with the delta, cart it up to altitude release and then make the run. The only power burnt by the delta at this point is the idle current of the esc and servos the mother ship provides the power for takeoff and climb. Now the hard part is to come up with the ESC, Motor and battery combo. To rough out the power, we are talking about 100 amps at 20 volts, or say 50 amps at 40 volts, that will give you 2 kw of power. Now the Phoenix HV-110 would work for an esc it can handle 110 amps at 50 volts but the price is very stiff! So the Phoenix HV-45 will probably be the choice still not cheap but closer to something I might be able to do at $160.00. Now for the hard part, the motor even the highest rated axi can only take around 40 volts at 60 amps for a short time but way too much weight. So I am still looking
_____________________________
The Wrights never crashed, they only had hard landings. I 've had some hard landings myself. AMA EAA AOPA revver #185
