RE: (Something Fast?) Delta Build Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: (Something Fast?) Delta Build Thread
Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
Login
RE: (Something Fast?) Delta Build Thread - 9/6/2007 2:46:38 AM
Mike Connor
Status: offline
quote:
ORIGINAL: daven
Just caught up on this thread, great job Mike. Did you have CAD knowledge before you started this, or did you learn on the go?
Thanks Dave,
I never used CAD until last May when I downloaded TurboCAD LE. I thought I could design and build a better Delta and went on my OCD crash course to make it happen. I had seen a drafting machine and knew what a vernier was before I started. You could also say I have a strong background in computers and aviation. Some of the guys in the scratch build and CAD forums probably remember me from all my questions. I have had a lot of compliments on the plans.
I would be happy to email (free of charge) anyone a copy of my plans in PDF format just for asking and I also sell the printed plans (E size - 34" x 44" for not much more then printing and mailing charges on my site. www.mikesrc.us
_____________________________
Mike
http://www.mikesrc.us/
(in reply to daven)
       Post #: 176
RE: (Something Fast?) Delta Build Thread - 9/6/2007 3:05:25 AM
daven
Status: online
I just started messing with TC LE also, I may come to you with questions
Dave Norman
klasskote.com
supertrc.com
(in reply to Mike Connor)
       Post #: 177
RE: (Something Fast?) Delta Build Thread - 9/6/2007 7:03:07 PM
Troy-RCU
Status: offline
quote:
ORIGINAL: daven
Now I know why Troy flies electrics
All that beach sand getting into his glow motors
Sand gets into motor bearings, too.
Can you feel that Buddy, HUH, HUH, HUH!!!??
I Have EXORSIZED the electrons, this plane is clear.
(in reply to daven)
       Post #: 178
RE: (Something Fast?) Delta Build Thread - 9/6/2007 7:52:14 PM
Razor-RCU
Status: offline
Inserts a witty comment about Dynamic Soaring here>
And talks about how all the records are held by gliders and junk---No engine/ Motor= no worries about sand and schrapnel!
Revver #5
(in reply to Troy-RCU)
       Post #: 179
RE: (Something Fast?) Delta Build Thread - 9/6/2007 11:32:31 PM
Troy-RCU
Status: offline
Huh? You just wait Razor until I fire up that 6.5 and get the pipe tuned in...
(in reply to Razor-RCU)
       Post #: 180
RE: (Something Fast?) Delta Build Thread - 9/13/2007 12:31:28 AM
ChuckL
Status: offline
Hey Mike you can relax it flies. I put two flights on it the first was preaty low speed about a hundred if I had to guess of course that was with only about half throttle. Trims needed a little adjustment not bad though and it was a very touchy on pitch. Prior to second flight adjusted throws and added 1/2 ounce to front since it was balanced more toward the aft limit. It was flying very good on this flight decided to try a full power pass started building up speed and the engine quit, carb decided to depart engine and I didnt have anything to tighten it back down with so that put an end to the flying. Overall very happy with the plane hopefully soon I will have a free day with decent weather to get some full throttle runs in.
       Post #: 181
RE: (Something Fast?) Delta Build Thread - 9/13/2007 1:42:54 AM
Mike Connor
Status: offline
Looking forward to future flight reports at high speed. I am curious about the CG. When it was touchy was the balance point behind the front spar?
Mike
(in reply to ChuckL)
       Post #: 182
RE: (Something Fast?) Delta Build Thread - 9/13/2007 2:24:35 AM
ChuckL
Status: offline
The 8.85" on your plans hit right on the center of the spar which I marked as the center I then marked plus and minus .4 for the forward and aft limit per your plans it was close to the aft limit behind the spar the 1/2 ounce on the nose put it right on the center of the spar or at least real close. It wasn't just the cg though I had a lot of throw on the elevators for the maiden so if things went bad I had extra in reserve which I also tamed down for the second flight so it would have been a combination, anyway CG right on the spar and recommended throws flying real good.
       Post #: 183
RE: (Something Fast?) Delta Build Thread - 9/13/2007 1:51:36 PM
bob27s
Status: online
well at least the airframe was well behaved enough to cooperate even with the aft CG and control throws... good testment to flying qualities.
Bob
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
       Post #: 184
RE: (Something Fast?) Delta Build Thread - 9/13/2007 8:09:08 PM
ChuckL
Status: offline
I agree Bob I think it is a keeper, I usually like an aft CG but this one seemed to be much happier on the spar overall seems like a good design. Launches are a non event it just blasts off.
(in reply to bob27s)
       Post #: 185
RE: (Something Fast?) Delta Build Thread - 9/13/2007 9:25:57 PM
Mike Connor
Status: offline
Delta COG is a little different and not as straight forward as a normal plane. With out looking at my notes I think the front spar is 15% MAC. I used a CG calculator, flight test and reverse enginered a Dust CG to come up with the front spar.
Another Demon flew in Florida the other day. It was built with a few shortcuts but he says it is fast. Picture attached.
Click to see fullsize image.
Click for fullsize
Mike
       Post #: 186
RE: (Something Fast?) Delta Build Thread - 9/16/2007 10:04:30 PM
ChuckL
Status: offline
I made two flights today both were full throttle from launch until the fuel tank was empty. We didn't get any timed runs on it but it was definately moving seemed much faster than my clipped dust but it still glides like a trainer also.
       Post #: 187
RE: (Something Fast?) Delta Build Thread - 9/17/2007 2:43:31 AM
bob27s
Status: online
sweet!
Bob Brassell
       Post #: 188
RE: (Something Fast?) Delta Build Thread - 9/17/2007 2:54:40 AM
Mike Connor
Status: offline
Great, I put two flights on my fun fly Demon today also and will post the results in my other thread. I will say that I bet yours was faster the mine.
Mike
       Post #: 189
RE: (Something Fast?) Delta Build Thread - 10/22/2007 9:48:12 PM
mmattockx
Status: offline
Bump
Any more pics or flight reports on these?
Mark
Waco Brotherhood #4
       Post #: 190
RE: (Something Fast?) Delta Build Thread - 10/22/2007 10:21:16 PM
Mike Connor
