gooseF22
IN, USA Status: offline
OK here we go...I ordered a kit from mike today. My first thought is my little 28-40-2500 medusa on 8 cells of 2300 A123 turning a 5.5x4.5 apc if I can get the nose streamlined enough. I am running this setup on 6 cells now with the same prop, so I will have to trim the prop a bit to prevent overload. I have gotten 65 amps from 6 cells with this setup, thats my first thought. just tweak the prop for a target of no more than 80 amps on 8 cells of 2.35 volts under full load. that little motor is a speed 400 by design, but it is simply amazing and doesn't heat. I mount it in a heat sink, and the ESC is in the wind. Its currently installed in a nitro .25 bobcat...the little yellow one that came out this year. It does about 100 with the 5.5x4.5 on 6 cells. I just ran medusa motor calc with 5x4.5 and 8 A123 cells. I think I will experiment with that on my bobcat when the weather clears as a possible elec setup. thats 22ounces of battery plus about 5 ounces of controller and motor. so the motor/radio gear with servos and BEC...about 2 pounds. 1200 watts and 40,000 rpm. Might require hearing protection though for the scream. A 5.25 inch prop maxes out at 44000 rpm, but it sure makes a ton of thrust when the tips are up around .9 mach.... What does the plane/covering comeout to?
_____________________________
Goose Team Fromeco
