.15 sized pylon racers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> General Racing Discussion >> .15 sized pylon racers Page: [1]
Login
.15 sized pylon racers - 6/26/2007 8:09:01 AM
Boo2
Status: offline
Hi,
I read that there used to be (or still is ?) a class for .15 cu in (2.5 cc) pylon racers in the USA. I have a piped MDS .15 and would like to build something fast for this as a training plane for jets so I thought that a .15 sized pylon racer would be ideal. Does anyone know where I can find a plan or (ideally) and ARTF of such a thing ?
Many thanks,
Boo
       Post #: 1
RE: .15 sized pylon racers - 6/26/2007 1:10:53 PM
j.duncker
Status: offline
The 1/4 midgets were fragile and not designed for a rear exhaust + pipe.
In your position I would scale down a Weston Magnum - wing flat plate 3/16ths balsa - upright engine and either fit twin fins or a V tail. Should be well mental.
Incidentally I had a MDS 15 great little engine 24,000 +rpm on a toothpick but it is noisy really really noisy. Hope your club does not have a noise limit because it won't pass.
_____________________________
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
(in reply to Boo2)
       Post #: 2
RE: .15 sized pylon racers - 6/26/2007 1:20:30 PM
Boo2
Status: offline
quote:
ORIGINAL: j.duncker
Oh I didn't know that, how did they cope with Rossi 15s and Cox Conquests then ?
Boo
(in reply to j.duncker)
       Post #: 3
RE: .15 sized pylon racers - 6/26/2007 2:56:26 PM
daven
Status: online
1/4 Midgets did have rear exhaust, but it was just a straight pipe coming out of the back. Non tuned, or muffled for that matter. Pipe was about 1/2" round by about 4" long. Not sure if a 15 sized plane is ideally suited for a Jet trainer though.
Dave Norman
klasskote.com
supertrc.com
(in reply to Boo2)
       Post #: 4
RE: .15 sized pylon racers - 6/26/2007 4:25:40 PM
fizzwater2
Status: offline
Back when QM's were .15's, it was my favorite racing event. The Nelson .15 used to run around 27,500 on the ground, and with that mini-pipe, it was quite a sound. I don't know if I'd call them "fragile" - they were glass fuse, sheeted foam wings just like the F1's, only smaller.
I wish they still ran the QM15's here.. lots of fun!
no matter where you go, there you are..
(in reply to daven)
       Post #: 5
RE: .15 sized pylon racers - 6/26/2007 6:28:54 PM
Boo2
Status: offline
quote:
ORIGINAL: fizzwater2
A glass fuzz / foam wing kit would fit the bill, does anyone still make one do you know ?
Boo
(in reply to fizzwater2)
       Post #: 6
RE: .15 sized pylon racers - 6/26/2007 7:16:07 PM
Electric Delta
Status: offline
Check out Matney Models at www.matneymodels.com , he has three different QM15 short kits available. Fiberglass fuselage, foam wings cores and plans; as far as I know, you have to supply your own wood and hardware.
< Message edited by Electric Delta -- 6/26/2007 8:39:42 PM >
Auf die Dauer hilft nur Power! Revver Brother #127
(in reply to Boo2)
       Post #: 7
RE: .15 sized pylon racers - 6/26/2007 8:03:48 PM
fizzwater2
Status: offline
in order for that link to work, I had to remove the comma at the end..
(in reply to Electric Delta)
       Post #: 8
RE: .15 sized pylon racers - 7/2/2007 5:32:31 AM
s-10promod
Status: offline
Take a look at Wild Hare R/C they have a LR1-A that would be what your looking for. Fizz I've still got a Conquest 15 also, but just bought a QM.40 so no budget left to do anymore projects at this time
       Post #: 9
RE: .15 sized pylon racers - 7/2/2007 2:46:37 PM
fizzwater2
Status: offline
As long as we're talking about .15 sized QM planes ( or what USED to be QM) - was it Ron Young that used to customize the conquest .15's with an ABC piston/sleeve combo, shaved down fins to fit a smaller cowl, etc?
I still have a couple of N15's, a stock conquest, and one of these customized ones. Just wondering if I was remembering the name of the guy that did the mods..
(in reply to s-10promod)
       Post #: 10
RE: .15 sized pylon racers - 7/3/2007 5:46:44 AM
s-10promod
Status: offline
Fizz, not sure about who used to work them. I had a deal with a guy I knew, He would buy a couple at a time from someone and use them for a couple races and replace them. That's where I came into the deal! I got nearly new ones for next to nothing and still ran like new for very little money!Dang, wish he was still around I would love to get a deal like that on some Nelsons!!!
       Post #: 11
RE: .15 sized pylon racers - 7/3/2007 2:43:00 PM
Dan Vincent
Status: offline
Fizz,
Here is a picture of my Ron Young modified Cox Conquest .15 for QM. He converted them to ABC as was mentioned.
Also here are three other rear-exhaust engines that were popular in QM at one time or another.
My Rossi came directly from George Aldrich. He said it was the best-running stock Rossi he had ever seen and decided to not modify it.
The Goldhead Taipan .15 is usually fairly cheap on ebay.
I can still hear those little screamers picking up RPM around the pylons. Loved the QM 15 Class, too bad it went away.
The last one is a Nelson .15 if you've never seen one.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dan Vincent -- 7/3/2007 2:44:51 PM >
       Post #: 12
RE: .15 sized pylon racers - 7/3/2007 3:05:44 PM
fizzwater2
Status: offline
Dan - thanks for the pics! My Young Conquest looks like that, I've got a Rossi courtesy of a good friend of mine, and there's still 2 Nelsons in my engine stash.. Guess I should look for one of those Taipans to round out the collection.
I agree, it's too bad that the class went away. I found a box of carbon fiber props the other day, too - one was marked "28,100" on it.. two or three of them were right out of the mold, not even finished yet. Those were wicked little knife blades, eh?
< Message edited by fizzwater2 -- 7/3/2007 3:06:39 PM >
(in reply to Dan Vincent)
       Post #: 13
RE: .15 sized pylon racers - 7/3/2007 4:08:17 PM
Dan Vincent
Status: offline
Yup, loved QM.
I still have a glass DH-10 fuselage and foam wings around here someplace, and two fiberglass Rivets fuselages and maybe 1 set of foam wings.
Also have a HOB Shoestring kit but someone started to build the nose section.
< Message edited by Dan Vincent -- 7/3/2007 4:09:26 PM >
       Post #: 14
RE: .15 sized pylon racers - 7/3/2007 4:17:30 PM
