Montague
Hmm, that's a rough one. If it was me, I'd probably ignore the going left on launch as long as the plane didn't also go left in a hard turn or loop. When I trim fly, one of the most important thing I do is max rate turns left and right. Any oddity in the rudder trim (twisted vertical stab for example) or wing oddities will often show up there with the plane always stalling the same way. The rolling thing is a little harder to figure, but it's probably one of a couple of things. It might just be your thumb moving off-center a little as you do the roll, and feeding in some elevator. Assuming it's not that, you might try some vertical rolls, espeically at idle in a vertical dive. It's most likely that you have a something in the aileron travel that's causing the ailerons to deflect unevenly. That uneven deflection is leading to just about a perfect amount of differential for a left roll, but a totally wrong diferential for a right roll. It's not uncommon for me to have a plane that rolls one way better than the other, or is more axial in one way than the other and unless it's really bad I usually don't sweat it. (after all, combat wings often get "dynamically re-trimmed", so a lot of time spent getting it "perfect" can easily be wasted when someone hits the wing and moves stuff around on you). Which also reminds me, make sure you're wing is on straight and level. I've also traced that kind of thing to problems with the aileron hinges or a bent pushrod. If the aileron LE can move vertically against the wing TE, then depending on the airflow and the pushrod and aileorn horn arrangement, sometimes servo deflection will rotate the aileron as desired, and sometimes it might move the whole aileron up or down instead, which can do some odd things to the roll. This often shows up as the aileron trim seeming to change a bit in flight on it's own as well, but not always. Hope that helps. AJ often reads these forums, hopefully he will pop in and comment on both problems.
_____________________________
Kirk Montague Adams RCCA 560
