RC Halftrack info
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> RC Halftrack info
Page: [1] 2 3   next >   >>
Login
RC Halftrack info - 6/26/2007 8:31:52 PM
PoisonPorkChop
Status: offline
Just wondering what everybody in our community might think about a RC Halftrack being done by Tamiya or someone else??? I for one would love to add a German Sd.Kfz.251 to my collection.
I have seen others here talk and attempt the project of RCing the 1/18 21st century halftrack ,but never saw if they were able to make it work,...if it was able to work ...what was used and how was it done??.
Just like to know how many others might be interested in a RC Halftrack and if there is enough does anyone know a good way to get a message to Tamiya.?????
Also I guess I couldn't expect a "Full Option" with sound and all ,with the limited space but .....maybe it is possiable???
Thanks for any info....I might try to get my 1/18 halftrack RC'd if I can get some info.
Thanks for any help!!!!
< Message edited by PoisonPorkChop -- 6/26/2007 9:11:31 PM >
       Post #: 1
RE: RC Halftrack info - 6/26/2007 10:32:36 PM
pattoncommander
Status: offline
Been doing a lot of thinking on that myself and was figuring, for a US halftrack like the
M-16 or M-3, building and towing an ammo trailer could carry the battery and the electronics. The motors could be under a "tarp" in the rear of the 1/2 track and a short drive shaft to the tracks. A similar setup could work on the 251 series. Cramped and not much working area, but I believe someone with time and a bit of engineering savvy could get them RC'd up and running. Now, with the M-16, to get the quad 50 mount to traverse and fire with fiberoptics in the barrels,, I'd put out a few $$$ on that.
(in reply to PoisonPorkChop)
       Post #: 2
RE: RC Halftrack info - 6/27/2007 12:55:38 AM
The_Stuff
Status: offline
i gots an idea now. dont know how well it would work but take a 2wd rc truck guts, make a rear drive shaft with locked dif or unlocked dif for the tracks. then make the front actually steer it. use that trailer idea for battery and heck even radio guts! make it looks like a supply trailer with an antenna! it might just work.
_____________________________
RC''s are like pringles... you can''t have just one!
(in reply to pattoncommander)
       Post #: 3
RE: RC Halftrack info - 6/27/2007 1:04:35 AM
pattoncommander
Status: offline
sounds like a feasable idea. OK, take a truck frame aready set up fpr RC and put the half track body on it. M-16's always had ammo trailers full of tombstone boxes because you just couldn't supply enought ammo for the 4 hungry ma deuces, and halftracks were alrays towing trailers. Now, find a 1'18 scale truck. Anyone energetic?
(in reply to The_Stuff)
       Post #: 4
RE: RC Halftrack info - 6/27/2007 5:04:15 AM
The_Stuff
Status: offline
hmm ya. 1/2 track from what brand is another question. never seen one in real life to say what would work better. I have a 1:16 team losi mini baja, but that was a 200 dollar truck. would work but im not going to hack it up. has dual 360 motors, a gear box, and is 4wd, has dual steering servos to. its overkill.
anyhow i don't know if a locked or unlocked dif would be best. if its locked then both treads move the same amount, making it more unlikely to hang up or have one tread spin in the air etc. dif lock switch would be nice but makes it more expensive.
I'm not sure what the stock 1/2 track front ends are like. I assume its all molded stiff suspension. I would change that out with springs etc from like tamiya semi trucks. just make a home made spring hangers and spring to a front axle.
also and idea for cables from trailer to truck is the tamiya semi's again. they have a multi cable from truck to trailer. bundles them up nicely. i don't recommend the actual cable though. it would be too light of wires. you would just need 2 or 4 wires for motor(s) + servo wire.
>.> ok i bought a 1/2 track off ebay ... 1/2 Track I blame you guys...
< Message edited by The_Stuff -- 6/27/2007 5:18:37 AM >
       Post #: 5
RE: RC Halftrack info - 6/27/2007 7:36:13 AM
Plastic scouser
Status: offline
HI Guys Trumpeter are to release a 1/16 static M16 halftrack maybe an R/C version will follow as that is what they did with the T34.
Heres hoping
Cheers Ian
Click to see fullsize image.
Click for fullsize
       Post #: 6
RE: RC Halftrack info - 6/27/2007 9:16:17 AM
raimian
Status: offline
does anyone know where you can buy 21st century models in the UK? as i would love to have a go at converting one to r/c.
(in reply to Plastic scouser)
       Post #: 7
RE: RC Halftrack info - 6/27/2007 9:29:07 AM
50Kaliber
Status: offline
quote:
ORIGINAL: Plastic scouser
Heres hoping
Cheers Ian
That sounds the way ahead, shouldn't be outside the realms of the expertise on this forum to convert a static model
Heng Long Tiger 1 - Full Metal and historic upgrade. WSN T34 - Next project
       Post #: 8
RE: RC Halftrack info - 6/27/2007 9:41:46 AM
uhu
Status: offline
You don't need to read german, the images are self-explanatory enough, it'a an SdKfz.251 1:18 brilliant conversion:
http://www.rc-panzerketten-forum.com/wbb2/thread.php?threadid=5463&threadview=0&hilight=&hilightuser=0&page=1
Cheers
Measure with a micrometer, mark with chalk, cut with axe.....
(in reply to 50Kaliber)
       Post #: 9
RE: RC Halftrack info - 6/27/2007 11:35:46 AM
thedonut
Status: online
Here's one...
http://www.tanktraxx.com/gallery/displayimage.php?album=4&pos=15
(in reply to uhu)
       Post #: 10
RE: RC Halftrack info - 6/27/2007 12:43:21 PM
50Kaliber
Status: offline
Awesome job, some people really have too much time on their hands!
(in reply to uhu)
       Post #: 11
RE: RC Halftrack info - 6/27/2007 1:49:58 PM
WhiteWolf McBride
Status: offline
Uh Guys...
Someone actually DOES make an R/C Sd.Kfz. 251, and uses the same method that the German modellers did to make the first R/C ones: used the Academy 1/25 Panther chassis & running gear, and went from there. You can get one for 190 to 200 euro, depending on which model you want.
http://www.michels-kinderwelt.de/ under Modelle - Militar 1:16
Have at it, guys.
WhiteWolf McBride - http://www.freewebs.com/whitewolf_mcbride/
2x Tamiya Leo 1A4, 1x M4A3, 1x M26, 1x T34/85, & LAV''s.
       Post #: 12
RE: RC Halftrack info - 6/27/2007 3:20:57 PM
PoisonPorkChop
Status: offline
HOLY CRAP!!!!!!
I want it so bad....but I have NO IDEA how or if I can order one...Dont speak or read German.....I didnt see a english version eaither....anyone else "Carry"them????? GOD..SOOOO CLOSE...HELP ANYONE????
(in reply to WhiteWolf McBride)
       Post #: 13
RE: RC Halftrack info - 6/27/2007 3:58:03 PM
The_Stuff
Status: offline
mine will not cost 200 euros, maybe 100~ when im done. or well so i plan :P
anyone know what that tamiya kit was on the german forum build link?
       Post #: 14
RE: RC Halftrack info - 6/27/2007 9:16:11 PM
pattoncommander
Status: offline
tried to contact Kinderwelt to check shipping of an RC 251 halftrack and a Sig 33, but the site says they will only ship to Europe. I just sent them a VERY pointed email, in German, requesting clarification or if we need to present our rabies shot papers to order. Waiting for response.
Bill
       Post #: 15
RE: RC Halftrack info - 6/27/2007 9:26:56 PM
