RE: FLITON - AJ Extra 330S "Build thread"
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: FLITON - AJ Extra 330S "Build thread"
Page: <<   < prev  4 5 6 7 8 9 10 11 [12] 13   next >   >>
Login
RE: FLITON - AJ Extra 330S "Build th... - 3/9/2008 2:14:12 AM
papajeff
Status: offline
quote:
ORIGINAL: paul5992
My plane is gonna build about 56oz. I called fliton and they said that is a little heavy. He said that my twin 3 cell 2200mah thunder power batteries is the reason for the weight. But I did some figures and the wing loading will be 17oz per square foot. The wing loading would have been 15oz per square foot at 50oz. I think the difference is minimal.
Paul,
The wing loading difference seems to be minimal, as you state. Please let us know what the results of your
flights are.
(in reply to paul5992)
       Post #: 276
RE: FLITON - AJ Extra 330S "Build th... - 3/9/2008 3:37:27 PM
wagen017
Status: offline
standard Fliton setup, so
This Ultra Combo pack includes everything that you will need to get this airplane in the air (quickly) and cost effectively. Also comes with a 4S (14.8v) 25C (continuous) Lipo 2150mAh battery. For all out wild 3D and instantaneous recovery, this is the setup you want.
INCLUDES:
FG AJ Extra 330s ARF
Hacker A30:10XL
Hacker X55 SB Pro Brushless ESC
(3) Hitec HS-81 + (1) Hitec HS-81MG Rudder Servos
(1) Fliton 4S 2150mAh Lipo Battery
(1) APC 13x6.5E Propeller
Dubro 1 3/4" Nylon Spinner (White)
Deans Connectors
24" Servo Wire Extension
For best IMAC performance, select Hitec HS-65HB servos from the above pulldown menu as replacements to the HS-81/81MG servos.
And yes, I selected the HS-65HB, only took a 81MG for the rudder servo.
_____________________________
Club Saito member #371
(in reply to papajeff)
       Post #: 277
RE: FLITON - AJ Extra 330S "Build th... - 3/11/2008 4:32:27 AM
papajeff
Status: offline
Volkert,
Thanks for the set-up info on your AJ Extra. Our weather has been so bad for the past few months that I
can't wait for a few good days to get some video & stills of my AJ. Winter......no fun!
(in reply to wagen017)
       Post #: 278
RE: FLITON - AJ Extra 330S "Build t... - 3/11/2008 8:41:40 PM
wagen017
Status: offline
I hear you on the winter part. I think in your parts it will be a bit worse then here, but I have seen enough of rainy windy days with low temperatures. Brrrrrr. really jealous about these guys a bit more south!!!!
       Post #: 279
RE: FLITON - AJ Extra 330S "Build t... - 3/14/2008 10:44:37 PM
paul5992
Status: offline
It just got over 30 this last week here. This has been the coldest winter we have had in a while. I'm kind putting of the AJ to get my 30% yak ready because its warming up fast now.
       Post #: 280
RE: FLITON - AJ Extra 330S "Build t... - 3/19/2008 7:14:31 PM
papajeff
Status: offline
AJ Extra appears at Chief's Auction as FLITON introduces Northeast Sales Rep, Lynn Bowerman.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 281
RE: FLITON - AJ Extra 330S "Build thr... - 3/24/2008 5:20:49 PM
franchu1
Status: offline
Hi guys great stuff, i am collecting my 330 FG tomorrow and have been checking out this thread for some heads up and i must say, i got some good info Thanks guys, I am from Trinidad and Tobago i fly RC Hells and Planes i currently own a Raptor 90 custom built right up,
and i Filton Inspire 60, laters
Francis
       Post #: 282
RE: FLITON - AJ Extra 330S "Build t... - 3/25/2008 3:01:57 AM
ryan_m
Status: offline
anybody tried the Eflite pro ESC's? They are supposed to be rated for full BEC from 3s to 6s lipo batteries... I'm planning to run mine with a 4s 2500 Flightpower EvoLite, Eflite Pro 40 amp
ESC. Need to check the wattmeter though and make sure on the amps. The specs from Horizon say the motor pulls 32amps or so. After reading about people using the 32 I'm starting to wonder if the Power25 will be enough...
(in reply to franchu1)
       Post #: 283
RE: FLITON - AJ Extra 330S "Build t... - 3/30/2008 10:38:01 PM
papajeff
Status: offline
Ryan M,
I have not tried the E-Flight pro ESC's yet, but I hear that they have been well received. With the Hacker
A30-10XL motor and X-55 Pro ESC, I have not had any power problems. I do think that you might be better
off with the Power 32 as it never hurts to have a little extra power in reserve, right?????? Also, don't forget
the rest of the power equation is the battery and I really have been extremely pleased with the Flight Power
packs.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to ryan_m)
       Post #: 284
RE: FLITON - AJ Extra 330S "Build t... - 3/30/2008 11:22:09 PM
OnTheEdge
Status: offline
Anyone want to share their landing gear mods? I just broke a second set today on what was not that bad of a landing. Little bumpy runway I guess did it.
Avoid zen aerobatics...when the ground........and the plane.......become as one.
       Post #: 285
RE: FLITON - AJ Extra 330S "Build t... - 3/31/2008 12:48:34 AM
Jake Ruddy
Status: offline
I am currently helping a buddy build one of these... Overall the quality if pretty low and dissappointing... it got even better when trying to install the aileron servos last night and one wing had the servo hole and supports on the wrong side of the rib.
He is going to try dealing with the LHS first for replacements.. then Fliton, I have heard bad things about product support from Fliton direct.. anyone have any experiences good or bad there?
(in reply to OnTheEdge)
       Post #: 286
RE: FLITON - AJ Extra 330S "Build t... - 3/31/2008 1:52:03 AM
OnTheEdge
Status: offline
Hi Jake, My experiences with them were very good. Very fast response to questions and help with issues.
(in reply to Jake Ruddy)
       Post #: 287
RE: FLITON - AJ Extra 330S "Build t... - 3/31/2008 1:58:59 AM
franchu1
Status: offline
I think this kit is top notch, Taking into mind what it''s designed for, Hell hard! extrema 3d i think AJ and Fliton did great job! man this bird floats. never the less sorry to here about you landing gear, seams like Fliton has to buck up a little the same thing happened to my Inspire 60 after it''s 3rd flight, had to splice in a peace of hard ply on the fuselage, it held up until i kissed the dirt, did not think twice to order another Fliton (AJ 330 FG), once this product is in the sky it all smiles,
< Message edited by franchu1 -- 4/18/2008 5:17:22 PM >
