rmenke -> RE: FLITON - AJ Extra 330S "Build thread" (9/28/2007 11:21:22 PM)
Papa: Looking forward to your flight report. As "strange" would have it, got anxious for my AJ pre-order to arive on the boat. In the intrum, ordered a Precision Aerobatice Katana MD which arrived 2 days ago. Thought to use some of the gear sitting in drawers gathering dust. I am very impressed with the build quality of this bird, by far the best that I have had so far through the years. First obsticle I ran into, neigher my JR 35 or 46 servos would fit in the aileron cut outs. Did not want to grind and extend, so did some research and ordered 4 Fatuba units with enough power required. Mounting my AXI 2808/20 required filling in existing mount holes, making a template and redrilling the mount, now done and fits fine. Hope it has enough power to 3D this thing, is good for 56oz, airframe is around 30, so should be good. Motor pulls 30A, so found a 2-3 year old CC 35 oz controller, 3.8 X 10 prop fired it up with a 3000 mah 3c 20C battery with the wattsmeeter between. Lots of air, but it cuts out at near full throttle and 28 amps. Changed controller to a CC 60, and wow, 30 amps right on motor limit and wants to scoot. So, ordered a new controller for the AXI and battery recommended, 2500 mph 3c. This morning I hear the old brown truck running around in the area, know its distintive engine sound, sure enough here is the new AJ, latest model with all the improvements. Quality of this bird is also high, not quite up to the Katana MD, but good. AJ gets the big 30-Hacker, 55 amp controller capable of running the bec and 4 servos. Will be interesting to see what bird flys the best, great reviews on both. Had better get off the tube and going on the AJ. Weather is supposed to be bad for a few days which is ok, will be building the AJ regardless. Will be printing out your build comments and getting with it after lunch. Hope your batteries get here today, am sure you are chomping at the bit to fly. ENJOY
