rmenke -> RE: FLITON - AJ Extra 330S "Build thread" (10/14/2007 12:43:54 AM)
Papa J: Feeling so sorry for you, have dug through 4 cabinets of misc. stuff, but no 1/8" axel, otherwise one would be in the mail. The machine bolts provided seem to work ok, although do not like them either. Finished the Katana MD, supprised I got it to CG ok with the battery. Now going to work earestly on the AJ. Should maden next weekend as not a bunch left to do. Intend to use a Castle 60A with new Castle bec and see if she will like the 4,000mah cell. If not, looking forward to your findings battery wise as we have the same motor. New experience last night. Ran Katana axi 2808/20 on 3,000mah bat., watt meeter said pulling 24 amps. Hay, I can use my Castle 35 on this and save the 54 for the AJ. Exchanged controllers, hooked her up and got the correct beeps, then the controller went up in smoke. Guess my electrical theory needs a little more work huh? Apparently the controller must be equal to the batterys max amps regardless of the motor demand. In this case battery is 20C, 60 max amps. ,demand on same 24 amps. Still wondering why poof? Gonna bug Red S a little. ENJOY
