Taildragger726
FL, USA Status: offline
Larry, none of us like the main wheels,, but they are light and work OK. The hard part is finding suitable axles thatwill work with the LG legs. The gear legs are rather narrow near the axles. Most aftermarket axles need such a large hole,, could comprimise the strength of the gear leg. Look around for wheels you like that will work with the stock 'axles'. The tailwheel is easily replaced with an aftermarket tailwheel assembly . PapaJeff,,, PING,,, Calling PapaJeff,,,,, Come-in PapaJeff,,,,
_____________________________
Also known as N726AC
