Gasoline engine plumbing
Tower Hobbies
Logged in as Guest
  Printable Version
Rich Model 35% Extra 260 - Add engine & rx - ARF
Seller:  ScaleFreak
Details:   $1,500.00   |  11/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> IMAC >> Gasoline engine plumbing
Page: [1]
Login
Gasoline engine plumbing - 3/6/2003 7:44:48 AM
jldecarlo
Status: offline
I am getting ready to assemble my first gas powered plane (a 3W fun Xtra).
What is the recommended method for plumbing the plane? Are you using a 3 line tank and fuel dots? What about a sullivan/dubro fueler?
Leonard Decarlo
Tyler, TX USA
       Post #: 1
Gasoline engine plumbing - 3/6/2003 8:15:02 AM
wgeffon
Status: offline
All you need to do is run a two line system.
The line to the carb needs a T on it to a fuel dot or something similiar. You wont flood the motor when fueling because your carb is a pump and no fuel will go that way till the motor is running.
_____________________________
Wayne
(in reply to jldecarlo)
       Post #: 2
Gasoline engine plumbing - 3/8/2003 11:50:00 PM
Geistware
Status: offline
Get the MIRACLE FUELER. Mounts to the side of your fuselage with a jam nut.
http://www.qualityrcproducts.com/miraclefueler.html
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 3
Gasoline engine plumbing - 3/15/2003 2:26:53 PM
pe reivers
Status: offline
Like a previous poster said:
A T-connection in the fuel line to the carb, with a fuel dot to round it off nicely.
One single vent tube in the tank, going up from the bottom to prevent syphoning action.
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
       Post #: 4
Gasoline engine plumbing - 3/15/2003 4:27:54 PM
Bob Pastorello
Status: offline
I use the Miracle Fueler, also. Has an o-ring seal, positive 1/2 turn locking action, large enough to get a good hold. Well worth it.
Bob Pastorello www.rcaerobats.net
Sponsored by RCGF Aero Products
       Post #: 5
Fueller - 4/3/2003 5:32:23 AM
Forgues Research
Status: offline
I like this fueller using 3 lines so as not to take any chance on having air to the carb.
Click to see fullsize image.
Click for fullsize
Evo Engines
http://forgues-research.com
       Post #: 6
Gasoline engine plumbing - 4/3/2003 5:33:10 AM
Forgues Research
Status: offline
another view.
Click for fullsize
Evo Engines
       Post #: 7
Gasoline engine plumbing - 4/3/2003 5:34:02 AM
Forgues Research
Status: offline
And the last one
Click for fullsize
Evo Engines
       Post #: 8
Gasoline engine plumbing - 4/3/2003 6:13:06 AM
Jleyland
Status: offline
Hi Roger - Those look cool - do you make them?
       Post #: 9
Gasoline engine plumbing - 4/3/2003 6:14:46 AM
Forgues Research
Status: offline
[QUOTE]Originally posted by RudderMagic
Hi Roger - Those look cool - do you make them? [/QUOTE]
Yes I do.
Evo Engines
       Post #: 10
Gasoline engine plumbing - 4/3/2003 6:18:44 AM
Jleyland
Status: offline
ok thanks
       Post #: 11
Gasoline engine plumbing - 4/3/2003 9:00:09 AM
OnTheEdge
Status: offline
[QUOTE]Originally posted by pe reivers
............One single vent tube in the tank, going up from the bottom to prevent syphoning action. [/QUOTE]
Pe, can you elaborate on the syphoning issues? I'm just in the process of running my vent line in my current project. Like my last plane, I just leave my open vent line hang (dangling) about 2 inches out of the bottom of the cowl.
Thanks.........Mark
Avoid zen aerobatics...when the ground........and the plane.......become as one.
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
