bullyhys
CA, USA Status: offline
quote:
ORIGINAL: The_Stuff ok looked at the word pad, but it didnt help with dis assembly. anyhow i figured out those track skirts. they do pop off, but are glued on with a strong glue, and i broke one peg. it can be fixed later. i found out the sachels inside and the fire extinguisher pop off cause they are glued on. got the top unscrewed and off. now i am stuck. how did you get the inside lower hull stuff out? the seats etc. also how did you get the drive wheels off? dose the fake motor pop out to? i think it has some plastic tab type things holding it on. also i think i am going to leave the steering and go full tank control steering for simplicity sake. i dont want to rip the steering apart etc if i dont need to. also for the seats did you just cut them out? Stuff, The inside lower floor I pried out( It's glued in place) using a large flat blade screw driver, the same with the seat floor and dash board, and engine. The oil pan I cut away what was necessary to install the steering servo. (I used a micro servo from a park flier RC plane.) A lot depends on what you plan to do with your conversion, are you just going to drive it around? Or are you planning to do RC Tank combat. When I started I removed as little as possible in order to keep as much of the halftrack intact as possible. Later as I found that I needed more room for electronics, only then did I remove the other stuff. The drive sprockets have to be pried or cut from the chassis. If you go with the tank steering idea you will have to make sure all the vehicle weight is on the tracks or it will not steer well. The front wheels axel can be removed from the chassis by removing the screw that is in front of the motor, then using a drift punch or a short piece of wire that fits in the screw hole, tap the axel assembly out from the chassis. Here is the link to the club web site with a improved writeup on the 251 conversion. http://web.mac.com/ksoc/iWeb/Special%20Projects/Merle%20Sdkfz%20251.html (Thanks KSOC ) My suggestion is to go slow and plan out what and how you want to go about doing this conversion. Note My 1st conversion took almost 2 weeks to do. Now I can get one ready in about 4 hours. To date I have done 3 german halftrack RC conversions. Halftracks 1&2 are posted here and else where, the third halftrack is to be traded to a member of our club. I hope I have been of some help. Regards bullyhys
< Message edited by bullyhys -- 7/9/2007 8:42:27 AM >
_____________________________
DBC/DBQ 39th Terran Lancers, Dinochrome Brigade "Stand and be Judged"
