Which Morris ARF ???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> Which Morris ARF ???
Page: [1] 2   next >   >>
Login
Which Morris ARF ??? - 2/23/2002 4:57:39 AM
RC_Junky
Status: offline
Of the new ones out, which would be your pick for best 3D and why?
< Message edited by RC_Junky -- Feb 23 2002 12:06AM >
_____________________________
"Something will happen, it always does."
       Post #: 1
Which Morris ARF ??? - 2/23/2002 9:04:06 AM
JohnVH
Status: offline
I would like to know which is the best 3D one also, new or not!
---AIR VH---*FURY FLYER* www.3DFoamy.com
(in reply to RC_Junky)
       Post #: 2
Which Morris ARF ??? - 2/23/2002 9:34:36 AM
m.gramling
Status: offline
I finished my top cap arf today. so far a well built arf. I was suprized to see such good quality in an arf. I used all of their supplied stuff, except the fuel tank. I put in a hayes because I am using a YS 63. You can probably put the plane together in a night, it is putting all the radio, servo trays, and everthing else that takes time.
The instructions aren't that good. they only hit on the high stuff. All the little things are left out. But if you have put a couple of arf toether, or build a few planes it shouldn't be a problem.
I ordered the knife video, that plane was amazing. the guy at morris I talked to stated" the knife more for learning to hover and knife edge. IT excels very well at that. the video showed it doing knife edge loops, inverted flat spins, tornados, tail touches," "the top cap can do that stuff plus tumble alot better, He states that can learn to hover on a top cap, but it is a little harder, but still very easiely accomplished.
I didn't ask about a sudokio, I know a guy that has a kit sudo, PaulSwanny, he will probablly reply on this topic. and i think he loves it, he is flying it with a mvvs 40. I saw him fly it, it has unlimited vertical, will do inverted flat spins, knife edge loops, all the good stuff. I couldn't believe the power the mvvs 40 had. it made a believer out of me.
I haven't flown my top cap yet, but it looks like it has great potential. I have YS 63, hi-tec 225s on elevator, throttle, rudder, -standard JR517 on alerons, 1100 mh batt. on my old fruit scale weighs 4.5lbs. (I don't know how accurate my scale is though)
IF all the arf that morris produces, are as good as my top cap, quality wise, I don't think you can make a bad choice.
       Post #: 3
Mostly agree with M.Gramlin - 2/23/2002 10:15:21 AM
CptCliffhanger
Status: offline
You could make one bad choice. The Knife! Man, that thing sure is ugly!!
I've flown all three ARFs. The Knife I flew was a basketcase. The fuse was bent and it really didn't fly straight! I can't comment on how one would fly with a straight fuse. But I can tell you, It sure is ugly!!
More important than wich one you choose, is how you set it up. A good engine - prop combination is important, as well as CG, and control throws, for your taste of flying. If it doesn't fly right, you're not done setting it up!
Check my review of the TC ARF in this forum "Morris Top Cap ARF".. Mine flew more perfect than I imagined a funfly could! I have made no adjustments since its first flight. 60 seconds into her maiden flight I was tapping the tail. besides, the TC just looks better..
< Message edited by captaincliffhan -- Feb 25 2002 4:49PM >
       Post #: 4
Which Morris ARF ??? - 2/28/2002 10:05:12 AM
JohnVH
Status: offline
I got mine and a new saito.72 today, did you guys use the stock pull pull cables?
       Post #: 5
Which Morris ARF ??? - 2/28/2002 10:45:24 AM
capthis
Status: offline
I have flown the su-do khoi with a ys 63 for some time now, and I love it. I also fly the Knife with a os 46 with the baffle removed from the muffler. A 11-5 MA prop on the 46 and it has real good power. The knife hovers better than the su-do-khoi, but it will not do the flips or the climbing flat spin as well as the su-do-khoi. The knife is easier to land thanks to its constant cord wing, it doesn't seem to want to rock as bad flying in a harrier with the wing stalled. Which one is better. It depends. If you are just getting started with 3d I would say the knife. If you want to take it a little farther then I would go with the su-do-khoi, or the top cap. Either way your not going to be disapointed. And you gives a rats fanny if they are ugly. Anybody that runs a profile down either hasn't had one or just can't fly one all that well. They are great planes to learn to hover and torque roll! Just my thoughts.
       Post #: 6
Which Morris ARF ??? - 2/28/2002 10:46:26 AM
capthis
Status: offline
The stock pull pull cables are fine. I have never had any trouble with them and I really wring these little things out!
       Post #: 7
Which Morris ARF ??? - 2/28/2002 11:39:38 AM
Shortman
Status: offline
now how do those top cap work??? they put all the stuff into the wings? someone explain im confused on how they do that?
Steven Carroll
AMA# 738035
       Post #: 8
Thick wings - 3/1/2002 12:17:16 AM
vertigo
Status: offline
Shortman,
Funfly planes generaly have wings 2 1/2 to 3 inches thick so there's enough room for all the radio gear.
       Post #: 9
Morris planes - 3/1/2002 2:42:27 AM
JWilliams
Status: offline
I have not flown the Morris arfs' but I have flown nearly every plane they have from a built up kit. You must ask yourself what you want to do? 3d? Then get the top cap or sudokhoi, they flip flop better than the knife, but the knife is easier to hover. If you have learned to hover go with the top cap or sudokhoi they are more challenging to hover and will develop your skills to a higher level in hovering. However, these three planes are all good fliers and you cannot go wrong with any of them. Best of luck and I attached a picture of my new edge. Jeff Williams
Hey vertigo, email me with where you are in Southern Illinois, I used to live there.
Click to see fullsize image.
Click for fullsize
       Post #: 10
The Knife Rocks! - 3/1/2002 6:00:29 AM
Slocum
Status: offline
Our club has gone Knife crazy! I love my ARF (top) the other two are kit built. It hangs on the prop like I am puting it on a hook! One of the other guys even started tail taping.
All of us use stock O.S. 46
< Message edited by rslocum -- Mar 1 2002 1:13AM >
Independent AMSOIL Dealer
http://amsoil.poseyflyers.com
       Post #: 11
knifes are great - 3/1/2002 6:20:49 AM
JWilliams
Status: offline
Hey that bottom knife used to be mine, I sold it to Bryan Baker glad to see it is in the air again. That very knife was on TV last summer and had its tail hovered into the water. I will post the picture of that soon. My old knife and the middle one were scratch built from plans by the same great framer Dave R. Happy contrails Jeff Williams
       Post #: 12
Sudukhoi - 3/1/2002 6:36:46 AM
FIVESQUARE
Status: offline
My experience....is the suki...
I have owned two......Still have one pristine....Anybody want it.....???
Just get tired of this 3d stuff.....I back in to scale landings and touch and goes.....
Guess I'm an ole fart.
5x5
When things start going wrong while airborne, its like the whole world is a tuxedo, and you are a pair of brown shoes.
       Post #: 13
Re: Sudukhoi - 3/1/2002 7:55:27 AM
RC_Junky
Status: offline
[QUOTE]Originally posted by FIVESQUARE
5x5
[/QUOTE]
All ways in need of replacements, talk to me........ASAP!
       Post #: 14
suki - 3/1/2002 8:14:01 AM
FIVESQUARE
Status: offline
This isn't the place to deal airplanes....contact me e-mail and lets not pee in someones wheaties
5
       Post #: 15
Which Morris ARF ??? - 3/1/2002 8:21:31 AM
funfly2005
Status: offline
