osterizer
MD, USA Status: offline
quote:
ORIGINAL: ezveedub I was looking at the Hitec HS-55's today. I think they are the same price range as the E-Flite S75's. I would prefer a faster tail servo though. I was looking at the Futaba S3114 for that job. It won't bolt in for the cyclic servo job though. Hole spacing is too small. Its actually pretty fast & has higer torque than all the other servos mentioned. While on the servo subject, I was doing some more preflight checks and tuning with the DX7 and found the right side servo was not centered (travel movement wise). At high throttle, when moving cyclic to the left it would stop moving while the other servo still was. Its a good idea to check your servo movement and install the arms centered. I should have seen this before when I was adjusting the subtrim. Actually, I've set mine up with the S3114s and with HS55s both. The 3114s are a little tight but they will screw in, and they do fly better than the HS55s, but the HS55s work well for general messing around, still. I use the S3154 and GY401 on the tail, but the S3114 would probably work fine, too, particularly with a less expensive gyro. A full Futaba setup on the King makes for a very strong heli. [edit] BTW-- if you crash a lot, get some extra arm sets for the 3114s. It's rare that they strip gears, but I think that's because they have very lightweight arms, and it's not uncommon for them to break even in a minor incident. [/edit]
