RE: Honeybee King v2 tuner shop
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: Honeybee King v2 tuner shop
Page: <<   < prev  14 15 [16] 17 18 19 20 21 22 23   next >   >>
Login
RE: Honeybee King v2 tuner shop - 8/18/2007 11:17:53 PM
Chash
Status: offline
Ha Paul , Battery on charger with try . when I ture the rutter to left it has a lot of power and spin quickly to nose left and when I put rutter to the right little . As soon as battery is charged I'll adjust real tail servo and see what happens Thanks
(in reply to snowbird6)
       Post #: 376
RE: Honeybee King v2 tuner shop - 8/18/2007 11:24:00 PM
Chash
Status: offline
Hay Snowbird I just upgraded to Sonix 30A Love the tones try turn the to throttle up plug in heli wait for two BB and throttle down . It might be throttle range setting
(in reply to Chash)
       Post #: 377
RE: Honeybee King v2 tuner shop - 8/18/2007 11:32:39 PM
Chash
Status: offline
Snowbird6 go on line to helitown.com/Grneral how to rc helicopter instuction videos go down page find Align ESC setup see if this helps good luck
(in reply to Chash)
       Post #: 378
RE: Honeybee King v2 tuner shop - 8/19/2007 1:42:35 AM
Danschmidt
Status: offline
yeah my swash is about worn out too...i need to get another. that'll keep the grips going for awhile... here is what i did for the meantime.. its a tail servo ball with a nut and a long screw...too long in this case , but it works.
oh btw here is a fix i did for the rollers on the belt it consists of 2 mainshaft bearings from my fp and a servo mount brass piece, and a longer screw..it works well
(in reply to osterizer)
       Post #: 379
RE: Honeybee King v2 tuner shop - 8/19/2007 1:51:56 AM
PaulG-RC
Status: offline
Thats a great idea good work.
Has anybody tried JR crystals in the E-Sky TX and RX ?
(in reply to Danschmidt)
       Post #: 380
RE: Honeybee King v2 tuner shop - 8/19/2007 1:53:25 AM
crashcrash
Status: offline
quote:
ORIGINAL: Danschmidt
LOL....nice fix on the belt problem. I haven't seen that one. You guys will note from his pic that the belt does NOT run in a perfect straight line from the pulley, through the guide rollers, and into the boom tube....and this IS the problem with dropping belt off the guide rollers. Two choices....wider rollers as shown here or raising the main pulley as I did. Either will work. Belt tension is CRITICAL gentlemen...too tight or loose will cause major headaches.
_____________________________
what?
       Post #: 381
RE: Honeybee King v2 tuner shop - 8/19/2007 2:00:34 AM
Danschmidt
Status: offline
i used to get king 1 mainshafts and drill the hole myself higher up...... i am getting lazy so i had to come up with something...
(in reply to crashcrash)
       Post #: 382
RE: Honeybee King v2 tuner shop - 8/19/2007 2:40:22 AM
ezveedub
Status: offline
quote:
ORIGINAL: snowbird6
What's wrong with my Esky brushless ESC (EK1-0350)?
All the sudden my ESC has stopped working! Normally when I power in on, I will hear 3 beeps (means no brake): B B B
Now when I power it on, I hear: BBB BBB BBB BBB (4 times, 3 quick beeps), and the motor is not turning anymore.
I disconnected the motor wires: same sequence of beeps.
The manual does not mention about this beep code at all. Does anyone run into problem? How do I get out of this mode? or is the ESC is dead? (my bad luck - only got this set from Rusty for about a month).
Sounds likes you have break enabled (shouldn't be). Like someone said earlier, place throttle stick at highest point with Tx on, then plug in the battery (sounds crazy, but thats the programming mode). Once Heli is on, bring stick to lowest point and see if the sound beeps come back to Bi Bi Bi. I am unsure though how to switch the brake on/off function though. You don't want that on because you will most likely strip your main gear if you engage it. Also, when I disconnect the motor wires only, I get no beeps at all. It seems to detect if the motor is connected or not.
< Message edited by ezveedub -- 8/19/2007 5:11:46 AM >
Hornet X-3D, Trex 450SE, Mini-Z
MP777, MBX5R , MBX5T, Inferno & Spada 09, MBX6, MP9
       Post #: 383
RE: Honeybee King v2 tuner shop - 8/19/2007 2:47:44 AM
ezveedub
Status: offline
I notice the frame flex from day one. With a 3900Kv motor, I come up slow on throttle. You came actually flex the motor/pinion away from the main gear (not good). Maybe the carbon frame kit has an aluminum motor mount. This is not abnormal for a lot of plastic frame helis though. This is one reason I don't go cutting away to mount bigger motors. I remove as little material as possible to keep the motor frame area as strong as possible. It not very strong to begin with. The motor screw area can get worn out after a few crashes, and you'll need bigger washers to make it mount the motor securely. CNC top frame would be a good mod.
       Post #: 384
RE: Honeybee King v2 tuner shop - 8/19/2007 2:57:10 AM
TheStapler
Status: offline
quote:
ORIGINAL: crashcrash
I fix my belt by just putting a washer between heli body and the flange bearing cover. now that has made the bearing sit alitte lower so it lines up with the pulley.
       Post #: 385
RE: Honeybee King v2 tuner shop - 8/19/2007 3:09:21 AM
ezveedub
Status: offline
[/quote]
[/quote]
There are many belt/bearing mod fixes. I find as long as it works, your fine. I found some Helimax MX400/450 bearings (flanged & regular) that are available from most LHS and washers that work perfectly over my original posted mod. Just install the longer bolts & cut them shorter as needed with the extra bearings. The washers are 2x3.2x.2mm washers. Perfect for correctly spacing the bearings apart when you stack them together as a roller.
(in reply to TheStapler)
       Post #: 386
RE: Honeybee King v2 tuner shop - 8/19/2007 3:59:34 AM
snowbird6
Status: offline
quote:
ORIGINAL: ezveedub
quote:
ORIGINAL: snowbird6
Sounds likes you have break enabled (should be). Like someone said earlier, place throttle stick at highest point with Tx on, then plug in the battery (sounds crazy, but thats the programming mode). On
