crashcrash
MI, USA Status: offline
Chief...Some of those T-Rex's have the 180deg swash like the bigger Kyosho's and whatnot. The EXI has the 120deg CCPM type swash. One of my MX-400's is running the 180 swash like the older T-Rex...it's not bad once you figure it out. One servo runs elevator, one runs aileron, and one runs collective and they are independent of each other instead of working collectively. Actually, it's interesting to see it work after just knowing 120deg CCPM only. The 180 config has some benefits, and it has drawbacks. The biggest drawback is the additional arms, levers and links required to make it work (more stuff to break) The 120CCPM upper for the MX-400 eliminates a lot of trash off the front of the heli (LMAO). The 120deg upgrade costs about $45...well worth it, I installed it before even flying it. My current radio (Eclipse 7) is programmable for ANY swash config.
_____________________________
what?
