Zimatosa
CA, USA Status: offline
My pitch curve in Normal Mode is something like 49, 50, 50, 75, 100....But to get the exact pitch you need at the low point, you will need to fuss a little bit with a pitch gauge and your linkage. Before you start this project, go to your swash mixing and set the pitch value at the highest you can go before bottoming out the center hub. You can then measure your pitch at the top end of FULL travel as well. I was recommended to unplug the motor to set the pitch instead of using throttle hold. Throttle hold seems to chunk the swash downward into a different realm of pitch. this would give you a false "flying" pitch value.... Have fun.... Z
_____________________________
Without deviation from the norm, progress is not possible.
