tbaus
TX, USA Status: offline
Jim, there is no reason you can't go to a 10 tooth. Are you using different lipos when testing in case you have a lipo that is going bad? If you think you have a headspeed problem, start turning the left knob counter clockwise. My setup with my Hacker has the left knob between 12:00 and 1:00 and the right knob about 3:00. If you have a pitch gage, unplug the leads from the motor and check what pitch you have at low throttle, middle throttle and full throttle. Something could have moved. Generally if you have a good motor and lipo ( nothing dieing) headspeed problems are because you have too much pitch set. Along with too much pitch comes a hard to get adjusted tail. Check for friction. If you adjust your tail rotor belt too tight, it really binds everything. Again, if you have a 10 tooth pinion and it is easy to swap, there is no reason you can't try it.. It may work... Tom
