RE: Honeybee King v2 tuner shop
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: Honeybee King v2 tuner shop
Page: <<   < prev  178 179 [180] 181 182 183 184 185 186 187   next >   >>
Login
RE: Honeybee King v2 tuner shop - 5/26/2008 6:30:11 PM
crashcrash
Status: offline
quote:
ORIGINAL: sd5ten
yeah the swashplate does go down from the up position, no way to fix this huh? TX means the radio? I'm a newbie..=)
TX means the transmitter (the radio you hold in your hand). Yes, the servos can be re-wired...but it's not easy to do. Someone mentioned in this thread that there are some switches inside the radio, and you can reverse that way but I don't remember much about it. I've re-wired the servos (HS-55's), it's NOT my favorite thing to do so if you can reverse it using internal switches...that would be the better way to do it.
_____________________________
what?
(in reply to sd5ten)
       Post #: 4476
RE: Honeybee King v2 tuner shop - 5/26/2008 6:33:50 PM
kenhiraihnl
Status: offline
here's a thread that addresses the problem...btw, if think you're beginning to like flying rc helis, and might stick with it, you might want to consider getting a computer radio...you'll be able to correct such problems and dial-in the exact combination of throttle and pitch settings that you want...ken
http://www.helifreak.com/showthread.php?t=70810
Raptor50V2│Raptor30V2│Logo10-3D(stretch)│Logo10(stretch) │Esky HBK2 2.4 │Gaui 200 2.4 │Walkera 4#3 2.4
       Post #: 4477
RE: Honeybee King v2 tuner shop - 5/26/2008 6:50:17 PM
sd5ten
Status: offline
thanks guys for the info, I'm going to try to re-wire the servos for now. I'm using HS-65HBs, do I just swap the power and ground inputs to the servos?
(in reply to kenhiraihnl)
       Post #: 4478
RE: Honeybee King v2 tuner shop - 5/26/2008 6:58:25 PM
Rosebud6
Status: offline
Personally, I'd go back to stock servos until you get a programable TX (radio). You can buy the gear kits for a few bucks. Usually only one of the gears strip and of course non of my LHS ( local hobby shops) carry gears for esky. I've only had one servo gear go out other than during crashes (about 4 of em). Amazingly enough my last crash from 30 ft didnt even scratch the servos but took out my ESC, battery frame, main frame amungst a few other things. Only other option is to search around for the fix to reverse the switch.
       Post #: 4479
RE: Honeybee King v2 tuner shop - 5/26/2008 7:28:36 PM
GTX SlotCar
Status: offline
quote:
ORIGINAL: sd5ten
I'm guessing that the servo operates the wrong way (don't have one), but no, you can't just swap the power and ground on the servo wire. You have to swap them inside the servo, swap them on the pot and on the motor.
Gary
SuperSkids® www.super-skids.com
       Post #: 4480
RE: Honeybee King v2 tuner shop - 5/26/2008 7:59:29 PM
sd5ten
Status: offline
I seen the motor, is the pot the part that gets three wires after the circuit board?
(in reply to GTX SlotCar)
       Post #: 4481
RE: Honeybee Ki... - 5/26/2008 8:05:51 PM
GTX SlotCar
Status: offline
quote:
ORIGINAL: GTX SlotCar
quote:
ORIGINAL: Zimatosa
...following websites have the same ...
Xheli.com
Raidentech.com
Nitroplanes.com
HobbyPartz.com
Sorry to bring up such an old post, but I guess we can add grandhobby.com to this list.
Gary
       Post #: 4482
RE: Honeybee Ki... - 5/26/2008 8:07:24 PM
crashcrash
Status: offline
quote:
ORIGINAL: Zimatosa
Xheli.com
Raidentech.com
Nitroplanes.com
HobbyPartz.com
LOL......
what?
       Post #: 4483
RE: Honeybee King v2 tuner shop - 5/26/2008 8:30:57 PM
Zimatosa
Status: offline
quote:
ORIGINAL: sd5ten
Here is a schematic of the switches in the radio...Hope these help and you do not have to rewire the servos.....This is a repost of a picture and explanation from a different post(on a different forum, in a different universe).
A - aileron & rudder. Up = AIL left, RUD right. Down = AIL right, RUD left.
B - pitch & elevator. Up = PIT right, ELE left. Down = PIT left, ELE right.
Mode 1 is A down, B up.
Mode 2 is both switches down.
1 - Pitch mixing. On = FP mode (90 deg swash), Off = pitch mixing enabled.
2 - Mixing mode. On = Belt style mixing, Off = CP2 style mixing.
Click to see fullsize image.
Click for fullsize
Without deviation from the norm, progress is not possible.
       Post #: 4484
RE: Honeybee Ki... - 5/26/2008 8:32:05 PM
Zimatosa
Status: offline
quote:
ORIGINAL: Zimatosa
Xheli.com
Raidentech.com
Nitroplanes.com
HobbyPartz.com
...and NitroRc.com....Double LOL!!!
I went to Xheli and read about becoming an affiliate. After reading the page, I believe that all these clones and semi-clones are just affiliates that link to the same products with a storefront. When you see Zims-RCHeli.com....You are welcome to go through my link to buy all those nifty EXI-450's...Hehehe
J/K
Z
       Post #: 4485
RE: Honeybee King v2 tuner shop - 5/26/2008 9:47:46 PM
sd5ten
Status: offline
thanks dude for the schematics
(in reply to Zimatosa)
       Post #: 4486
RE: Honeybee King v2 tuner shop - 5/26/2008 10:25:30 PM
GTX SlotCar
Status: offline
quote:
ORIGINAL: sd5ten
Like I said, I haven't seen that servo, but yes, a pot should have 3 wires.
Gary
       Post #: 4487
RE: Honeybee King v2 tuner shop - 5/27/2008 12:29:36 PM
tvarvais
