RE: Honeybee King v2 tuner shop
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: Honeybee King v2 tuner shop
Page: <<   < prev  180 181 [182] 183 184 185 186 187 188 189   next >   >>
Login
RE: Honeybee King v2 tuner shop - 5/29/2008 9:14:31 PM
reel109
Status: offline
It is a wag, not up and down
Jim
_____________________________
Always waiting for parts.
(in reply to Rosebud6)
       Post #: 4526
RE: Honeybee King v2 tuner shop - 5/30/2008 3:07:30 AM
jecchile
Status: offline
HI! guys... I am a new HoneyBee King 2 owner and have a lot to learn...
Question: If you replace the radio equipment installed in the HBK2 with, for example, a Spektrum radio, how would you "set up" the Idle-Up switch, Gyro switch, HOV.PIT knob and the PIT TRIM knob?... or would you lose this capabilities?...
Also, the PIT servo, where would it plug into?... in the E_sky receiver it goes in port#6 (channel 6)...
Thanks for your help...
(in reply to osterizer)
       Post #: 4527
RE: Honeybee King v2 tuner shop - 5/30/2008 4:31:19 AM
crashcrash
Status: offline
quote:
ORIGINAL: jecchile
LOL.....where do you start? DX6/DX6i/DX7?, AR6000/AR6100/AR6100E? Spektrum radios being programmable can compensate for the knobs where you don't really need those knobs...see pitch/throttle curves section.
what?
(in reply to jecchile)
       Post #: 4528
RE: Honeybee King v2 tuner shop - 5/30/2008 4:45:56 AM
jecchile
Status: offline
Thanks "Crashcrash"... I guess I should be more specific...
The radio I want to use is a DSM2 Transmitter that came with my previous heli, a Blade CX2. It is a transmitter named LP5DSM and works with a AR6100e receiver. It will save some weight and then it will also take me out of a frequency which is crowded... my radio came on channel 52 and a lot of guys are in that channel.
This is a "basic" transmitter but it is a Spektrum setup... it has all the 4 standard channels (Aileron, elevator, throttle, rudder) on the sticks and 1 knob that is for channel 5... the only other switch available on the transmitter is the "Train-Sw".
Do you think I can use this setup?...
Thanks.
(in reply to crashcrash)
       Post #: 4529
RE: Honeybee King v2 tuner shop - 5/30/2008 6:33:16 AM
Zimatosa
Status: offline
quote:
ORIGINAL: jecchile
Thanks.
I doubt that the radio is going to be able to do proper swash mixing for the CCPM....I am not familiar with that radio so from here, I would only be able to hook you up with a great set of values for the DX6i or DX7. Check out the DX6, DX6i, DX7 thread....
Peace,
Z
Without deviation from the norm, progress is not possible.
       Post #: 4530
RE: Honeybee King v2 tuner shop - 5/30/2008 6:39:41 AM
Zimatosa
Status: offline
That servo I fried a day or so ago was replaced by a Hitec HS50. Seems like the piro rate is doubled with this servo. If anyone else installs this servo with DX6i, I had to re-reverse the channel(back to Normal) and re-reverse the gyro(back to A on Telebee) to get it to work. It is purdy sweet compared to the stock rate of the Esky. Remember to put a piece of tape over the joint where the case snaps together. These servos have no screws holding them together and they open very, very easy. I came to find out!
Peace,
Z
(in reply to Zimatosa)
       Post #: 4531
RE: Honeybee King v2 tuner shop - 5/30/2008 7:21:33 AM
crashcrash
Status: offline
quote:
ORIGINAL: jecchile
Thanks.
I agree with "Z" and since the CX2 is a fixed pitch unit, I doubt it's CCPM (all servos operate together on the throttle and pitch). Here's a hint...DX6's are getting a lot cheaper because of the DX6i and DX7. The DX6 uses the AR6000 RX which can be purchased off E-Bay for $42 shipped...the DX6 is capable of 10 model memory and isn't that hard to program, Look into it.
what?
       Post #: 4532
RE: Honeybee King v2 tuner shop - 5/30/2008 2:35:00 PM
GTX SlotCar
Status: offline
quote:
ORIGINAL: jecchile
....The radio I want to use is a DSM2 Transmitter that came with my previous heli, a Blade CX2. ...
If you can post a picture - take the batteries out of the Tx and take a picture of the battery tray. There may be some (3) square holes in it, and under the holes could be 4 micro switches. One of these could set the Tx for built-in CCPM mixing and another for the direction of swash movement. Some of the Esky Tx's are done this way.
Gary
SuperSkids® www.super-skids.com
       Post #: 4533
RE: Honeybee King v2 tuner shop - 5/30/2008 3:52:17 PM
jecchile
Status: offline
Thanks guys for your replies...
The LP5DSM TX does not have any micro switches in the battery compartment. Took the batteries out and looked carefully. NOTHING. It is a great little radio for "foamies" and flying indoors so I guess I'll use it like that...
Changing crystals in the E_sky TX and RX would be a lot simpler to get to a less crowded frequency...
Anyone knows what type (Futaba for example) of crystals this TX/RX will take?
Thanks again.
(in reply to GTX SlotCar)
       Post #: 4534
RE: Honeybee King v2 tuner shop - 5/30/2008 11:17:28 PM
USHobbySupply
Status: offline
My understanding is that the Esky uses Single conversion xtals. Futaba single conversion will work. Never tried but thats what i've been told
M
Michael Bernstein, President, USHobbySupply
Please PM me if I miss you question in a thread
       Post #: 4535
RE: Honeybee King v2 tuner shop - 5/31/2008 12:10:13 AM
jecchile
Status: offline
THANKS... I will give them a try and see what happens.
(in reply to USHobbySupply)
       Post #: 4536
RE: Honeybee King v2 tuner shop - 5/31/2008 5:17:26 AM
sheerider1026
Status: offline
hey guys, i did get my treex flying finally!! and i fell in love! very smooth flying(its a copterx clone) i also got the spektrum blackout problem fixed on my hbk2.. i noticed that the rx's were flashing instead of having the leds constantly on.. i remounted the rx and
