RE: Honeybee King v2 tuner shop
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: Honeybee King v2 tuner shop
Page: <<   < prev  181 182 [183] 184 185 186 187 188 189 190   next >   >>
Login
RE: Honeybee King v2 tuner shop - 6/1/2008 9:12:27 AM
crshk2x
Status: offline
Zim thanks I'll check my settings,........................NO MY CONTROL ARMS NOT BACKWARDS LOL !!!!! although I can achieve some remarkable " well bless your heart ". after I posted I got it out checking tracking, once again no lift until 80%, dropped throtle to 50% flipped OSS ( oh s- switch) and immediately went neg pitch DOH !! Should have checked that long time ago .......didnt think CF with wrong spacer would throw it out of pitch that bad .
(in reply to ArrowNaughtic)
       Post #: 4551
RE: Honeybee King v2 tuner shop - 6/1/2008 2:45:29 PM
Bones27
Status: offline
Information, for you guys that like the 8g E Sky servos, I was on the manufacturer web site today and they have a message scrolling saying that production of the 8g servo has been stopped and it has been replaced with a 7.5g digital servo. I don't know how many of the 8g servos are still in hobby shops (online or LHS) but if you want some spares you might want to order them soon.
_____________________________
Don''''t let schooling interfere with your education.
Mark Twain
(in reply to crshk2x)
       Post #: 4552
RE: Honeybee King v2 tuner shop - 6/1/2008 3:02:29 PM
Rosebud6
Status: offline
Hopefully the gears are the same then it wont really matter until a servo dies.
(in reply to Bones27)
       Post #: 4553
RE: Honeybee King v2 tuner shop - 6/1/2008 8:11:06 PM
jecchile
Status: offline
OK ArrowNaughtic... I stand corrected on the Hig/Low frequency break...
Maybe "computer" radios are more sensitive to frequency stability but I've heard that plain old radios can be changed and they work fine. I knew that if you went from High to Low or Low to High you have to re-tune the TX...
       Post #: 4554
RE: Honeybee King v2 tuner shop - 6/1/2008 11:43:56 PM
crashcrash
Status: offline
quote:
ORIGINAL: Rosebud6
Initial reports are the 7.5 is a POS...I hope it isn't so. Some people think the 8G is a POS, but they're immensely better than the S-75's or HS-55's. It's kinda weird but the standard sized servos I use in my AeroStar .40 have lasted since the late 1980's, and have been crashed many times, never had to replace one of them...ever (I have both Hi-Tec and Futaba standard servos in two different planes).
what?
(in reply to Rosebud6)
       Post #: 4555
RE: Honeybee King v2 tuner shop - 6/2/2008 2:28:52 AM
Zimatosa
Status: offline
I traded in my HS50 for two tower pro 9G's.....Now funflier can't call me names and laugh at the size of my................Servo!
Z
Without deviation from the norm, progress is not possible.
(in reply to crashcrash)
       Post #: 4556
RE: Honeybee King v2 tuner shop - 6/2/2008 3:42:20 AM
sheerider1026
Status: offline
i am using some s-75's in my hbk2.. they seem ok so far.. i also have one esky 8g in there also.. i tried to fit some hs-55's in it but they did not fit right.. where are you guys buying the tower pro servos at?? i have never seen any before.. are they a lot beter?? i am using hs-65mg's in my trex and i must say they are top notch servos in my opinion.. they are pricy but i am sure they will pay for themselves in the long run!!(we all crash don't we?)
(in reply to Zimatosa)
       Post #: 4557
RE: Honeybee King v2 tuner shop - 6/2/2008 4:08:14 AM
KCinNC
Status: offline
i'm using the esky 8g servo's in 4 heli's on the cyclic....i've only had 1 servo go bad
(in reply to sheerider1026)
       Post #: 4558
RE: Honeybee King v2 tuner shop - 6/2/2008 4:26:40 AM
crashcrash
Status: offline
quote:
ORIGINAL: KCinNC
That's what I mean.....the 8G's are fine, why discontinue them? Stupid.
what?
(in reply to KCinNC)
       Post #: 4559
RE: Honeybee King v2 tuner shop - 6/2/2008 4:43:26 AM
Zimatosa
Status: offline
I am posting a link to a re-mod for the center fly-bar holder....
I know some of you curmudgeon's never leave the Tuner thread so here ya go!
Link to the link, to link to the link
Peace,
Z
       Post #: 4560
RE: Honeybee King v2 tuner shop - 6/2/2008 4:42:27 PM
DRSutliff
Status: offline
Hey Guys,
I just got a new HBK2 (my first "real" Heli), and am upgrading to a brushless motor. I understand the motor does not come with a pinion gear, and the gears do not have set screws. How do I get the gear onto the shaft?
Thanks for the help and I will probably have more basic questions in the future as I'm just getting into this hobby.
DR
(in reply to betapilot)
       Post #: 4561
RE: Honeybee King v2 tuner shop - 6/2/2008 5:13:58 PM
betapilot
Status: offline
Don't bother removing the stock pinion, when you get your new motor get new pinions with set screws. I personally run align and have never had a problem with them, I also have been running the rhino gears and can't say they are any better than the aligns. I would still recommend using a dab of loktite even with the set screw pinions just to ensure hold. Depending on which motor you get will depend on the output shaft size, (there are two standard sizes, 2.3mm & 3.17mm) you may need to alter the way you mount the pinion on the shaft due to the size of the opening in the frame. I do not even run any 2.3mm shaft motors anymore so I have to mount the pinion either upside down or dremel out the opening ever so slightly to accommodate the larger pinion but well worth it in my opinion
On the servos, I received in my first shipment of the 7.5g stockers and have had a chance to test them for durability and performance. First thing I noticed is they definitely center better than the 8g's but are not any better from what I can tell in performance, they can post all the specs in the world about speed but these are no quicker than the 8g's, performance is almost identical to the 8g's. Having said that, tail control is slightly better and more precise and for the money I would find it tough to complain, they did perform well at the tail. I know the big question is how tough are they and I refuse to wreck the helicopter they are mounted on intentionally so you will just have to wait I do it by accident (won't be long I promise) to find out, lol. I will say this in all fairness, at this price I feel like they heartier than the eflites and cheaper than any other servo that is as good, I do not believe they went backwards but also do not feel they made any advancements. The word I got from esky was the change was made due to the fact that esky plans to upgrade their kits to a version of the art tech hh gyro as standard equipment like the art techs in the near future and they wanted these servos to accommodate the upgrades. All in all, in my opinion they are still a good buy for the money.
Rusty
Castlerock Hobbies
(in reply to DRSutliff)
       Post #: 4562
RE: Honeybee King v2 tuner shop - 6/2/2008 6:25:45 PM
