betapilot
OK, USA Status: offline
Hey Jim, I use only the hdx or microheli, no offense chill but the esky stuff is crap. I have used MH or hdx for over a year now and every single time I install one or send one out to a customer for them to run I get the same response of how incredible the difference is. The upgrade collar is 8mm and the boom on a king is 7.5 so you will have to run a spacer, I use an aluminum collar insert that I custom make for each of my applications that I include if a customer wants, or you can use heat shrink which works pretty well. For those of you still looking to extend your boom, the upgrade is a perfect fit for an art tech falcon boom which with minor dremel work fits a king very well, it will give you an extra 1/2 inch extension and increase the tail hold (or dumb it down) pretty well. The MH or hdx upgrade has multiple benefits performance wise where as the esky stuff is at best stock replacement parts in metal, I have tried other cnc upgrades and as Crash stated you can really get some junk out there. The MH or the hdx runs $55 so its not like it is way more expensive than its lesser counterparts and there is no comparison in the toughness and performance, best I have found on the market.
_____________________________
Rusty Castlerock Hobbies
