Davidjb
NH, USA Status: offline
quote:
ORIGINAL: Zimatosa As long as you are setting the helicopter up with all the trims in the center and the throttle stick at center it can be done either way granted you are setting the pitch and throttle curves for 3D and Normal the exact same at 50-75-100. There is another debate on where your trim should be for throttle....My heli's ESC works the best when I set trim all the way down. Just remember that wherever you choose to leave the trim, program the ESC AFTER you choose and leave it alone....If you have a stock radio, i suggest doing it in normal mode though, I am not totally sure that the normal and 3D mode are the same at 50-75-100%???? Anyone, anyone....? If you have not seen the set-up videos for the head, I recommend them highly. Even though they are not Kings, the information can be cross referenced... Peace, Z I've watched some of the videos, big help in setup, I don't see how the previous owner even flew it as it was way out of whack. I'm using the stock radio right now, a Futaba is in my near future though, I was thinking the 6EX. My thought was that (with the stock radio) I should set it up in idle up mode because that's when you should have 0 degrees pitch at center stick, is that correct? Not that I'm going anywhere near 3D flight any time soon, but I want it set up correctly. I know when I switch radios I'll have to set it up all over again, I found a really good video on setting it up with the the 6EX but now I can't find where I saw it.
_____________________________
Helicopters don’t fly, they beat the air into submission. Falcon 40, HBK2
