Zimatosa
CA, USA Status: offline
quote:
ORIGINAL: joeyhatch11 When I spin the Main gear, the motor spins and that's it. When I spin the blades, everything else stays still. Where is this screw that you guys are talking about? Follow the main shaft up with your fingers/eyes. The screw will be held on by a recessed nut just above where the head starts and the main shaft ends. If you broke it off, you may only see a mounting hole....Just look on both sides for a cavity that a hex nut would fit. I believe in Heli talk, this would be the "Jesus Pin", or so I have heard it referred....IE: You sheared your Jesus Pin...That could explain your problem though...Let us know what you find. Also, don't get too discouraged. These heli's are temperamental and touchy and can be a PINA...It's half the fun of owning these Fargin bastages!!! Peace, Z
_____________________________
Without deviation from the norm, progress is not possible.
