funflier
CA, USA Status: offline
Ok so you got a bent main shaft. Now for the bad news. They come like that! Yep, really, I have had them with runout at .015 from center right out of the package. That was like 3 out of 5 of them. If you have one thats bent on the bottom you can be sure you didn't bend it. Virtually impossible to bend one at the bottom without breaking the frame or tearing up the main gear. Just keep on takeing them back to the LHS till you get a stright one is all you can do unless you have a couple of matched V and V blocks, a dial indicator and a big F hammer!.
_____________________________
Kingll,3800/10t,cnc head,customcnc/trextail, 43t,Turnigy40A ESC/UBEC bult in,Telbgyro,Dx6i w/6100eRX,HS-65 serv,futab3114tai
