joizeex
NJ, USA Status: offline
quote:
ORIGINAL: reel109 Hi all, Had a minor crash the other day. Took out the blades, feathering shaft, and main gear. Now I notice that one of the servo's (stock esky) output shaft starts to shake when the throttle is in a particular position. This does not sound to me like a gear has broken inside it. Don't know what to do except to replace it. Any thoughts? Jim does the servo kinda skip a few degrees and click? one of mine does that after a crash, at lower swash positions and after opening it i found one of the gears had a broken tooth. the heli still flies fine because this doesn't happen in higher swash positions, i just can't fly inverted. i already bought a spare servo, but i'm still using the old one. does anyone know if they sell just the gears?
_____________________________
Kyosho: FW05-T WRC Evo6, TR-15 StadiumForce, InfernoGT WRC Sti, Seawind; Heli: HoneyBeeKing, Evo50, 4#3B; 1:1 Mitsubishi Evo
