joizeex
NJ, USA Status: offline
well, i just got back from flying my Evo50 and HBK back to back. i gotta say, i really don't feel confident with stock gyro to do anything but tail-in and side-in moving about, where as on the Evo i was actually flying all over the field every-each-way. i had to set the gain on the esky a bit lower last time because it wagged, yet today the tail would rotate on throttle up and throttle down in the air. not to mention that if i gave it sharp rudder input and let go, it would snap back like 30 degrees. definitely not good for noob pilots like me, or ones even noobier than me. i can't wait to get the telebee. in other news, the Xtreme plastic blades V2 are pretty good so far. they're noticeably more flexible than woodies, hence my previous boom strikes from emergency landing too quickly. i'm trying to partially remedy that by setting pitch to 0 at bottom stick, so that they don't get forced down by negative pitch. as someone mentioned on this or another thread though, when you get more durable blades and harder feathering shaft (like i did), other stuff will bend (my main shaft and tail boom got pwned more than with woodies). so just a reminder for all, to keep that in mind. oh yea and i'm flying with 2 servos that each have 1 broken tooth on a single gear now lol. only binds at the extreme negative pitch though.
_____________________________
Kyosho: FW05-T WRC Evo6, TR-15 StadiumForce, InfernoGT WRC Sti, Seawind; Heli: HoneyBeeKing, Evo50, 4#3B; 1:1 Mitsubishi Evo
