ezveedub
FL, USA Status: offline
quote: ORIGINAL: betapilot Hey guys - Hows tricks? I thought I would post my next brainstorm here and offer it out to whoever needs one. Originally I did the collar fix for the lowering belt syndrome and it has worked very well from reports back. Well, as things go, I have developed the next generation of upgrade/tweak for the lowering belt syndrome that I feel will work as well but offer a little more security. Something about a brass race just didn't work well with me, very loose tolerances, so I felt a bearing would work better in that spot to reduce drag and friction and wear. I could not find the right I/d and O/d and heighth, so I talked with a bearing mfg here in the city and they are making me some bearings per spec that will replace the collar all together. It should be better fit with better tolerances and should still be pretty inexpensive. They are supposed to be ready by the end of the week and I will let everyone know a cost soon. Rusty Let us know what you come up with on the belt/bearing mod. I been hunting down bearings but coming up with some odd combos. My real issue is the screw that holds the bearings for the belt. Its too short for what I want to try. As for the rollers, they made them too narrow and offset to high. These roller/bearings need to be wider than the belt. At least thats how the belts run a on Nitro RC car. My serpents runs three bearings, about double the width of the belt for side play amd movement.
_____________________________
HBK2 Modded, Hornet X-3D, Trex 450SE, MP777 WC, MBX5R , MBX5T, Mini Inferno 09 & Spada 09 OS Speed, JP B5N & B8N, Axe R
