RE: Honeybee King v2 tuner shop
Tower Hobbies
Logged in as Guest
Users viewing this topic: lohchief, imalama, Optimus110103, michael34614
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> RE: Honeybee King v2 tuner shop
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Honeybee King v2 tuner shop - 7/20/2007 8:11:56 AM
Pawel Rzedzicki
Status: offline
quote:
ORIGINAL: betapilot
Pics of the tail upgrade - careful when you do this, you must reverse gyro and rudder switch on tx. took me a minute to figure that one out, but man is the tail awesome now. pitch adjustment is made by moving the servo forward or backward, super easy. Well worth the money, feather shaft is super strong, no bends here. Also, check the canopy, fit perfect with no mods and almost no change to the cg. crappy pictures, I need a new camera.
Rusty
I upgraded mine tail with alu too. But didnt need to reverse servo and gyro. Dont you know why you had to do it???? You have the belt spinning tail rotor reversely. Tail rotor should turn in the same direction main rotor does. And looking at the picture i see the tail rotor blade's leading edge looking back. You have to disassemble your tail rotor, take off the belt, turn it 180 degrees, assemble everything again, take off the blades and put them back properly. Unreverse servo and gyro and enjoy real good done upgrade
(in reply to betapilot)
       Post #: 76
RE: Honeybee King v2 tuner shop - 7/20/2007 2:25:23 PM
ezveedub
Status: offline
quote:
ORIGINAL: Dave_E
ezveedub, where did you get the skids? Thanks, Dave.
Got them from any LHS that carries Align parts. Just look or ask them for the Trex 450 skids. Look for the complete set, as they sell just the plastic legs set in diifferent colors and the entire landing skid set with frames, tubes, screws & antenna tube. Should be 7-8 bucks.
_____________________________
HBK2 Modded, Hornet X-3D, Trex 450SE,
MP777 WC, MBX5R , MBX5T, Mini Inferno 09 & Spada 09 OS Speed, JP B5N & B8N, Axe R
(in reply to Dave_E)
       Post #: 77
RE: Honeybee King v2 tuner shop - 7/20/2007 2:32:21 PM
ezveedub
Status: offline
quote:
ORIGINAL: osterizer
quote:
ORIGINAL: betapilot
Hey guys, I have been reading all the battery hype and it is not really that crucial. I run an eflite 10c 800 mah battery, in fact they are my favorite battery due to weight. They only last about 5-7 minutes real flight time, but the stock battery will do the same at about 7-9 minutes. A battery that has a high c rating will discharge faster and if you run it in a 1800 -2200 mah battery, the extra power will be used up lifting and keeping the extra weight in the air. The ideal battery for long life and flight times is a 10-12c MAX and 1200-1350 mah and nothing over 90 grams. Look at it like this, if you use the "bathtub analogy" it will become evident to you that overpowering your bird with a big battery is a waste of money and time. The voltage is your pipe and the pressure contained therein, the mah rating is capacity that the bathtub will hold, and the c rating is the size of the valve allowing the water in. Running a big battery is like putting a really big fuel tank in your truck and then adding a gas mileage chip to increase fuel pressure and then running extra large fuel lines and then throwing a trailer loaded down with bricks on the back, are you going to get better gas mileage? no, you are only going to burn more fuel. Large batteries are for large helis with lots more power that can overcome the weight . I am currently running a 430xl with 60a esc on one of my kings and I run it with the eflite, the stock, a dynam 1200mah 12c, and an electrafly 910 mah 12c. All of these batteries will fly perfect for 5-7 minutes before the esc shuts it down from heat. I speak from experience here, not myth or braggart rights, and I can guarantee you that running these massive batteries will only create more heat, more wear and tear, and may extend your flight times by 2-3 minutes at best. Keep in mind the greater the discharge capacity, the greater the heat and your esc is designed to shut down at a given temp range, you should not fly a good battery more than 70% depleted anyway if you want it to last. I only fly my batteries for five minutes max anyway, my batteries usually last me two years pretty easily and will almost always meet their cycling capabilities running them that way. Heat and weight are our enemies and you should do everything possible to keep those variables in check, this is not drag racing guys, helis don't react well to force, they prefer finesse.
betapilot-- agree with much of the above, but whatever you do the King will burn between 60 and 90 Watts in hover, regardless the current rating of the battery. What drives the power used is not the current capability of the battery but rather the powertrain drag, the weight it's trying to accelerate, and the maneuvers you do (how much acceleration you're demanding). The current capacity of the battery has nothing to do with how fast it discharges; however, the larger the battery capacity, the more it usually weighs, but some buck the trend; my current favorites are the Thunder Power ProLite 1350s-- at 80g they are the greatest, but the MegaPower 1350s at 100g fly well, too.
If you're running the same heli with the same motor with the same flight profile, head speed, and so forth, you'll get the same current draw no matter what current the battery can supply.
You should choose your battery such that it doesn't weigh too much, it fits in the airframe, and it can supply sufficient current. A good rule of thumb is to not use more than 75% of the battery's current capacity; a 1000mAh 10C battery, at 7.5A is only good for hovering. A 1350mAh 15C can be relied on to put out 15A, which is good for moderate aerobatics. 3D in the King 2 can require 20A, so you'd be looking for at least a 20C if you were using 1350s.
As for all the batteries mentioned, due these balance the helicopter CG? Are you running the heli tail heavy or adding weight to balance the CG? From my stand point the stock battery is just a bit small for size heli.
(in reply to osterizer)
       Post #: 78
RE: Honeybee King v2 tuner shop - 7/20/2007 4:35:07 PM
sdmahr
Status: offline
ezveedub,
I looked all over for the 2x5x2 bearing and cannot find them where I don't have to buy 10 to get some. I finally settled on trying a 2x5x2.5 which I could buy inexpensively in any quantity I wanted. I think from your pictures an extra .5mm will fit in there. If not, I'll dremel a little relief to make it work. So, I'll be trying a flanged bearing thats 2x5x2.3 and a plain shielded roller thats 2x5x2.5
Is yours still working O.K. ? I like the fix you have posted here and hope it is still working well for you as I'm about to dive in and mod BOTH of my HBKII's.
Thanks for sharing,
Scott
If you want to watch me fly it is at your own risk. I scare myself ! !
(in reply to ezveedub)
       Post #: 79
RE: Honeybee King v2 tuner shop - 7/20/2007 5:03:02 PM
ezveedub
Status: offline
quote:
ORIGINAL: sdmahr
ezveedub,
Thanks for sharing,
Scott
I know about the quantity issue. You may be able to use the 2x5x3 flanged stock bearing with a 2x5x1.5 instead and stack the cone washer on top. Thats only .2mm wider than mine and only needs 2 bearings, not 4 for each HBK2. Those are available single piece from VXB, but are open, not shielded. I haven't had any belt jumps yet, but I'm down right now wiring in some connectors. On the M2 bolts, I trim as needed depending on what bearing combo you use. You have very little room above the frame before it hits the servo mount. Each plastic molded frame is a little different.
(in reply to sdmahr)
       Post #: 80
RE: Honeybee King v2 tuner shop - 7/20/2007 6:45:58 PM
osterizer
Status: offline
quote:
ORIGINAL: ezveedub
Yes, the King seems to be chronically tail-heavy; in stock form it's sometimes ok, but once you add a decent gyro, fix the sloppy tail pushrod, &c it needs help. The little batteries don't help-- the ProLites are nice becuase they're so light for the power they put out, but you need to push them pretty far forward to balance. The only ones I have that balance the heli sitting all the way in the frame are the Great Planes 1500mAh 20C (http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXMDN1). At 140g they're at the top end of the weight I'd want the King to carry, though I know of people flying 180g (!) batteries, but they'd be great for someone practicing hovering and circuits.
Agree on the stock battery-- it is just marginal for the stock setup; with a brushless or maneuvering it gets really hot from the power needed.
       Post #: 81
RE: Honeybee King v2 tuner shop - 7/20/2007 7:12:57 PM
betapilot
Status: offline
Well. i don't know what to say here. I looked at every heli and used the simple torque offset of the main rotor theory and have yet to see a heli that its tail rotated the same direction of the main. I have falcons and eskys and a real life robinson that all turn counter to the main. All stock kings turn counter to the main. Perhaps you are running a different tail upgrade or read the manual and are repeating what the maunal said which is 180 out in the illustration. I have done 6 of these and all have been the same way and all fly perfect but I do not know everything and may have learned something here. Maybe I just don't understand you, but if you look at your king, the main spins clockwise, and then look at your tail, it spins counterclockwise and that is the same with all helis that I know of, trex, art tech, esky, eflite, and heli-max, it is simple physics. I actually just went and looked at my align to give you the benefit of the doubt and guess what, it spins opposite of the main. Tell us which upgrade you used, I may start using it if it is that easy but I will still have to call you on the same direction spin from tail and main, that makes no sense.
I saw the belt uprgade veedub and it looks good buddy, I thought I would post a pic of mine and I am trying your method tonight. Good info buddy, appreciate it. On the battery, I did move it froward and got rid of the horizontal stabilizer and went with a different canopy all to offset the cg, I prefer mine to lift node heavy personally. I understand what is trying to be said about the discharge rate and draw of a battery but one thing was mentioned that I strongly disagree with and it is a myth that has been perpetuated too often. I have personally witnessed bone stock king on a stock battery do pretty much every 3d stunt in the book, I cannot fly inverted without a crash but I have a friend that does competitions and can do all the stunts, he is 15, go figure. I sold him a king and straight out of the box with MINOR set-up, he flew it in every direction known right there in my front yard. I can guarantee that you do not need a big powerful battery for anything you plan to do with your bird but they will help in extending flight times. I only speak of what I have experienced personally and since I do not fly anything over 90 grams, I have not flown the bigger batteries since I did my testing when I first received a king. I flew it with two identical batteries, one a 10c dn battery and the other a 15c dn, both with 1300mah and the 10c flew longer by 3 minutes and still does. I thought the same thing would be the case but my stopwatch says differently. On the 450 se, I am also an align dealer and have owned two se's, the exact opposite was the case, the 15c ran the same time as the 10c but they were 1800mah batteries. Like I said, I do not know it all, I only speak of my experiences and the experiences of the pilots I fly with and personally witness their outcomes.
Rusty
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Rusty
Castlerock Hobbies
(in reply to Pawel Rzedzicki)
       Post #: 82
RE: Honeybee King v2 tuner shop - 7/20/2007 7:17:46 PM
Old Oiler
Status: offline
Hey Rusty,
What type of radio, receiver and servos do you use on the HBK II or do you still use the stock radio, etc?
mitch
Old Oiler
       Post #: 83
RE: Honeybee King v2 tuner shop - 7/20/2007 7:45:22 PM
npereira
Status: offline
From what I know, the Main turns clockwise and when on the right side of the heli looking at the tail, the tail turns counter-clockwise. if your standing on the left side of the heli, yes the tail does turn clock wise.
I guess it all depends where you phisicaly are standing.. left of right side?
Regards,
(in reply to Old Oiler)
       Post #: 84
RE: Honeybee King v2 tuner shop - 7/20/2007 8:45:52 PM
Lucubrate
Status: offline
Where can I get a set of those tall blue belt guides? Thanks.
