ezveedub
FL, USA Status: offline
Thats a fine blade pitch adjustment. The left knob is more of a coarse pitch adustment. Depending on the servo positions and stick position, it may not do anything at certain throttle/speed settings, more so on full throttle. Just unplug your motor from the ESC and power up the bird. With the blades fully extended, Idle up switch on and throttle stick centered, you should be at 0 Deg or flat level blades. I usually use the knobs to level my blades, as long as I have god + & - pitch with idle up on, and good + pitch with idle up off and throttle stock above halfway up.
_____________________________
Hornet X-3D, Trex 450SE, Mini-Z LM MP777 WC, MBX5R , MBX5T, Inferno 09 & Spada 09,
