titan starting problem    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> Turbine Clinic >> JetCat Turbine Direct Support >> titan starting problem
Page: [1]
Login
titan starting problem - 6/28/2007 6:19 AM
MLefebvre
Score: 100
Last Login: 5/22/2013
Status: offline
~S~
A friend of mine have a Titan. ( problem): almost each time we try to start it the temperature goes up to fast and the turbine seize .
We have lower the propane % first ( no good result )
after a couple of hour of head scratching we have try to control the kerosene at startup with the manual shut up valve and it works ,. With the manual valve we have been able to control the flow of kerosene and at the same time the heat at startup , turbine run perfect after that.
We have lower the voltage of the pump at startup and the problem almost disappear ( from .225 v to .125v)
Something to do for 100% safe start?
Sorry for my english
Martin Lefebvre
Canada
Hide Signatures
       Post #: 1
RE: titan starting problem - 6/29/2007 11:15 PM
mr_matt
Score: 116
Last Login: 5/23/2013
Status: online
quote:
ORIGINAL: MLefebvre
~S~
Martin Lefebvre
Canada
Hi Martin,
Your troubleshooting is good, as you lower this startup voltage the startup temps should lower. The good news is that your turbine likely is very powerful, so if you can control the startup you should be able to have a nice powerful turbine.
Call me at (805) 907-4462 and I can help you with other tips to enjoy this turbine!
Regards,
_____________________________
Matt
Hide Signatures
(in reply to MLefebvre)
       Post #: 2
RE: titan starting problem - 6/30/2007 4:58 AM
MLefebvre
Score: 100
Status: offline
Thank`s he will be happy
Martin
Hide Signatures
(in reply to mr_matt)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.330RCU1
