RE: Alternative fuels for glow engines
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Alternative fuels for glow engines
Page: <<   < prev  1 [2]
Login
RE: Alternative fuels for glow engines - 7/3/2007 10:09:19 PM
w8ye
Status: offline
Cool Power oil is all synthetic and mixes with methanol readily
All caster is very easy to get. The usual brand seen is Sig
But you can use drug store castor also
You can get Omega oil which is a mix of synthetic and castor
Klotz sells Benol and Super TechniPlate as well as methanol and Nitro-oil. Look on their web site
http://www.klotzlube.com/storeCats.asp?ci=8
< Message edited by w8ye -- 7/3/2007 10:15:19 PM >
_____________________________
Attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to meowy84)
       Post #: 26
RE: Alternative fuels for glow engines - 7/3/2007 10:42:08 PM
Jim Thomerson
Status: offline
It was posted on another forum that a horse supply place or vet would have castor oil in quantity. Not sure why.
(in reply to w8ye)
       Post #: 27
RE: Alternative fuels for glow engines - 7/4/2007 12:59:50 AM
somegeek
Status: offline
Helps with colic I believe.
Fly safe, have fun. Measure three times, cut once. The man who makes no mistakes does not usually make anything.
(in reply to Jim Thomerson)
       Post #: 28
RE: Alternative fuels for glow engines - 7/4/2007 1:58:36 AM
PlaneKrazee
Status: offline
I use Klotz castor or Sig. One of the main advantages of ethanol over methanol is it doesn't produce nitric acid when burned so your bearings will last longer and you can use caged needle bearing con rods without fear of them failing as when running methanol. OS seems to have been able to get ethanol to work in glow engines. I have read that ethanol has 40% more btu's than methanol, still less than gasoline but I don't know the exact figures off the top of my head.
KB1DTB
AMA11123
(in reply to somegeek)
       Post #: 29
RE: Alternative fuels for glow engines - 7/4/2007 2:25:20 AM
gkamysz
Status: offline
Ethanol's lower heating value is 35% higher than methanol. The air fuel ratio also means that only 71% as much ethanol is burned per cycle. It ends up a wash in BTU per cycle, theoretically. You also have to deal with combustion efficiency. There must be some loss there otherwise the engines would make similar amounts of power.
Mixing fuel using E85 should be pretty economical. I'd like to know how the glowplug is different. I'm thinking it use a different metal for the element.
I doubt you will see roller bearings in sport engines any time soon.
Greg
(in reply to PlaneKrazee)
       Post #: 30
RE: Alternative fuels for glow engines - 7/4/2007 2:34:14 AM
gkamysz
Status: offline
I just found that the AX-55-BE makes .95HP @ 10kRPM. The FSa-56 four stroke is rated at 1.0HP @ 10kRPM. Sure the AX-55 makes 1.7HP @16k but most people don't run it at 1.7HP. Most are probably closer to 1-1.2hp. Anyone have a HP plot of the AX-55?
Greg
(in reply to gkamysz)
       Post #: 31
RE: Alternative fuels for glow engines - 7/4/2007 5:15:27 AM
XJet
Status: offline
quote:
ORIGINAL: Skypilot_one
Eh, this is all news to me.
The combustion byproducts of methanol are nothing more than CO2 and water. Where does the nitric acid come from?
Here is the formula if you're interested:
2CH3OH + 3O2 → 2CO2 + 4H2O + heat
If you're running nitromethane then there is nitrogen added to the equation which can lower the PH a bit but methanol is a very clean-burning fuel that doesn't create any nitric acid.
Nitromethane may create acidic combustion byproducts when used with methanol, but it will also do the same if used with ethanol.
When I'm not here, I'm at RCModelReviews
       Post #: 32
RE: Alternative fuels for glow engines - 7/4/2007 6:28:30 AM
PlaneKrazee
Status: offline
Greg,
The OS 55 eco engine may have roller bearings. It is supposed to use much less oil thanstandard engines from my understanding of the advertisment.
XJet,
Just passing on what I have read and also what I have learned from guys running methanol in drag engines. Raw methanol can be very corrosive and will begin to corrode those engines sometimes in minutes, they don't have oil mixed with the fuel to help prevent it. They would wipe the parts down and wash them in gas to prevent it. Have you ever seen the process of how it's made?
B
KB1DTB
AMA11123
(in reply to XJet)
       Post #: 33
RE: Alternative fuels for glow engines - 7/4/2007 9:19:21 AM
XJet
Status: offline
What they're probably referring to is the corrosive effect that pure methanol has on many alloys of aluminum.
       Post #: 34
RE: Alternative fuels for glow engines - 7/4/2007 1:31:45 PM
PlaneKrazee
Status: offline
quote:
ORIGINAL: XJet
XJet,
Yes,
I believe that is correct. Why would that be if it is just alcohol?
I think the products of combustion change a bit due to the methanol manufacturing process. I had purchased a (used) 4 stroke model engine that had a weak aluminum case that had been attacked by the fuel. Some areas were close to crumpling.
< Message edited by Skypilot_one -- 7/4/2007 5:18:29 PM >
KB1DTB
AMA11123
(in reply to XJet)
       Post #: 35
RE: Alternative fuels for glow engines - 7/4/2007 2:04:24 PM
Sport_Pilot
Status: offline
As Xjet said there is no nitrogen from methanol so there is no nitric acid. But even if true, how did it get into the bearings? There are no bearing issues when using nitromethane, other than when running high RPM's.
Incomplete burning of nitromethaned produces nitric acid, but its not there till it burns. Even a small amount of methanol allows nitric acid (a potent rocket fuel) to burn off in the atmosphere. It is not a signicant pollution hazard such as nitric oxides from a gas engine, which our engines do not produce because of the low temps.
< Message edited by Sport_Pilot -- 7/4/2007 2:12:37 PM >
“I Saw Elvis at 1000 Feet” John Force
(in reply to XJet)
       Post #: 36
RE: Alternative fuels for glow engines - 7/4/2007 5:14:04 PM
gkamysz
Status: offline
quote:
ORIGINAL: XJet
That assumes perfect oxidation of the fuel. What happens when the engine is run rich like most are? There isn't enough oxygen available to complete the reaction.
One could assume that there are roller bearings in the AX-55-BE, but I wouldn't go that far. OS doesn't have a single engine with a bearing rod. OS documentation on the Bioethanol reads like propaganda. It gives this really good feeling about saving the earth and quotes only one thing about the nitric acid. Castor has been and could be used as a bio friendly lubricant. Methanol can be bio friendly depending on how it's made. Ethanol is just a catch phrase today to keep some people happy. Whether or not it turns out practical and powerful remains to be seen. I'm looking forward to seeing it. I'd love to get a hold of a glow plug.
So the engine uses less oil? Well, wait a minute. The engine already uses less fuel. So if the engine burns 40% less fuel in one hour it will have used 40% less oil even if the oil percentage is the same! Their advertising isn't technically wrong or misleading, it just doesn't define the standard it's being compared to.
Greg
(in reply to XJet)
       Post #: 37
RE: Alternative fuels for glow engines - 4/11/2008 6:27:07 PM
borna
Status: offline
One option is to convert your engine to run on Gas like what I did
http://www.rcuniverse.com/forum/m_6165393/anchors_6165393/mpage_1/key_borna/anchor/tm.htm#6165393
Borna
       Post #: 38
RE: Alternative fuels for glow engines - 4/12/2008 1:11:57 AM
Jezmo
Status: offline
Hey borna, how's it going? How is the 120 running?
Raptor 50 V2 OS 50 Hyper, T-Rex 450XL CDE, Spektrum DX7, SuperTigre OS FOX Saito Enya Jett TT
(in reply to borna)
       Post #: 39
RE: Alternative fuels for glow engines - 4/12/2008 1:39:41 AM
the Wasp
Status: offline
after running 2 gallons of straight Methanol (no nitro) threw my son's 180 Magnum 4st I can say it's not for this engine, it would take as many is 10, 15 flips to start it and it would idle ruff,, while with 10% nitro it would start with 1 flip,, and (of-course) idle better/smoother and produce more power..
Jim
(in reply to Jezmo)
       Post #: 40
RE: Alternative fuels for glow engines - 4/12/2008 4:17:22 AM
borna
