Sport_Pilot
GA, USA Status: offline
quote:
ORIGINAL: XJet quote:
ORIGINAL: dieseldan Ed denatured ethanol ( non drinkable) is available and is not taxed used in alcohol stoves and dish warmers. an other thought mole of methanol 1 carbon, ethanol 2 carbons isopropyl alcohol 5 carbons it would appear many more BTUs per unit in isopropyl but would it work as glow fuel?? martin Denatured alcohol (sometimes called methylated spirit) is often very "wet" -- ie: it has a high water content when compared to methanol. This water content can cause real problems. However, if you can get guaranteed "dry" denatured alcohol it'd be worth a try. Ethanol, isopropyl, and denatured alcohol are more expensive than methanol. In fact methanol is only slightly more expensive than gasoline. I can't see any advantage in running these alcohols in its place, there isn't even much change in efficiency. If you want to save money then you should be looking at running some gasoline in the mix. It costs less and because it runs leaner and hotter, thus more efficient, you use less fuel.
_____________________________
“I Saw Elvis at 1000 Feet” John Force
