WHMC
MO, USA Status: offline
Guys, Have now 10 flights on the machine. Robart did good, as far as retracts. H9 the design! Little note, keep the steering cables out of the way of the nose strut. 3/16 ply verticals maybe 1.5 long with a 3/16 standoff on each end. Glue to sides of wells with steering cable outside between vertical and well. Had the steer wires catch on ret. mount pinion and made for a nose gear collapse. Now all's fine now. Weight, all-up, Electric 16 lbs. These motors have instant acceleration, so 100 ft you are off, without flaps. Do land with full flaps, power on till runway under you then power off gradually and flare! Simple right, yes. Running TP 5000 packs and get 10min. Recharge and both packs take within 100mah of each other so the power system is right on. Handles the wind great. As this is my first scale war-bird a person can get hooked. Thumbs UP. Wayne McCosker STL
