CorsairJock
MI, USA Status: offline
quote:
ORIGINAL: timothy thompson yes sir completley diffent engines strengthened wing box spars. no turrets. new landing gear and tires. 2 tons heavier that a normal 29. she had more truss spars in the wing to deal with the shock wave.................................the basic shape looks the same but the internal mods make them completley new aircraft. So,........having stenthened wing spars (all internal mods I assume) , removing the gun turrents, and having different engines would make it virtually impossible to transform an R/C B-29 model into the Enola Gray? And makes it a "completely different" airplane"? I am no master modeler, but I am pretty sure that I could handle such a transformation. quote:
ORIGINAL: timothy thompson jock google b-25 b and b-25 j and look at the fuse shape the b was a prettier airplane more rounded and aerodynamic. The slab sided J carried a variety od weapons 75mm caqnnon up to 18 50 cal ect so they were stronger............................ I took your advice about Google and found this: http://www.fighterfactory.com/airworthy-aircraft/b-25j.php Take note of these statements: "Very minor changes were made as new variants were produced. The B-25A had extra armor and self-sealing fuel tanks. Two turrets, one above and one below the fuselage, were added to the B-25B. The "C" variant could carry more fuel and also had external bomb racks. North American opened a new factory in Kansas City, which designated their B-25's as "D" variants. These early models of the B-25 we not only used by the United States, but were also supplied to the Soviet Union, the Royal Air Force, the Netherlands, China, and Brazil. Except for larger engines and more weapons space, no other obvious changes were made to future variants." Lastly, there are a few makers of plastic model airplane kits that take great pride in the detail and accuracy of their model. Tamiya and Accurate Miniatures are two of them. They both typically produce multiple versions of the same basic aircraft. They include extra parts which 'convert' the model to whichever version is being built. I HAVE the Accurate Minuatures B-25B. Altho it is marketed as the 'B, and has all of the Dolittle Raider decals, it also has parts which could be used to transform it into a 'J, or other version. BUT, it only has one set of fuselage halves, BECAUSE THEY ARE THE SAME BASIC AIRFRAME. Guns are addeed, guns are mounted in different locations, canopys and windows change, there are different engines, butthe same basic airframe remains unchanged. An exception would be the B-26 Marauder, which had larger wings installed on later models, OR the P-40 which had longer tails on later models, but most aircraft remain basically the same from the 'A model to what ever. My Squadron/ Signal book does not indicate that there were any drastic changes to th |
