modawg73
Joined: 1/18/2008 From: Mason, OH, USA Status: offline
quote:
ORIGINAL: show871 Flew my B25 for the first time this weekend, and with the .36's it was SKEEEEEEETCHY! I need way more power where I am @, has anyone successfully mounted saito .82s? Is the carb to far back hitting the firewall? If so has anyone done os .55ax's? I have one on another plane and it actually is super quet and deep sounding with the stock muffler. Any pics or feedback on .55ax? Thanks 871 871, Check out the following page with the dimensions posted for the .82. Saito Single Cylinder Manual It is slightly bigger than the .62s that I have mounted. I think it would fit without major modifications. I had to drill holes further forward on the engine mount. Then I had to move the cowl forward, and used blocks on the firewall to accomplish this. My guess is that the .82 would fit fine. The reason I had to move the engine forward was the throttle arm. In my setup I used flexible steel cable for the throttle control, and there wasn't enough room for the needed play to work properly. I think it would fit. Whether or not it is too much power for the plane is another discussion entirely. Ken
