RE: New Hangar 9 B-25
Tower Hobbies
Logged in as Guest
  Printable Version
Canopy Rails for Warbirds - ARF
Seller:  NCIS
Details:   $20.00   |  11/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: New Hangar 9 B-25
Page: <<   < prev  12 13 14 15 16 17 18 [19] 20 21   next >   >>
Login
RE: New Hangar 9 B-25 - 9/14/2008 4:43:35 AM
modawg73
Status: offline
Charles,
Just be carefull. I thought the same thing until I realized that I had the gear in upside down.
Ken
(in reply to Charles_e_bates)
       Post #: 451
RE: New Hangar 9 B-25 - 9/14/2008 2:45:43 PM
Charles_e_bates
Status: offline
Thanks Ken,
I;ll check that out
Charles
(in reply to modawg73)
       Post #: 452
RE: New Hangar 9 B-25 - 9/15/2008 1:53:46 AM
500575
Status: offline
Or maybe 300 for the air retracks without the air tank kit 500 575
(in reply to oriole)
       Post #: 453
RE: New Hangar 9 B-25 - 9/22/2008 11:36:16 AM
raveon
Status: offline
Dear Ken
Stuck with the original set up that i used before of os40fxs stripped the engines down cleaned the carbs out and reset the idle settings engines were running really nice at full power and idle so i took her for her maiden flight on sunday afternoon and she flew really nice take off was about 200 yards and landing was perfect on two main wheels then nose.I think it must have made difference having two pilots in her looking after her
Best regards Ray
(in reply to raveon)
       Post #: 454
RE: New Hangar 9 B-25 - 9/23/2008 2:37:15 AM
Charles_e_bates
Status: offline
Ok,
Look at my B-25 !!
Should be on the ground next week and in the air next month
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Charles_e_bates -- 9/23/2008 2:53:46 AM >
       Post #: 455
RE: New Hangar 9 B-25 - 9/23/2008 3:06:36 AM
modawg73
Status: offline
quote:
ORIGINAL: raveon
Dear Ken
Best regards Ray
Ray,
Glad to hear it went well! I am looking forward to flying mine tomorrow. I am converting her to 2.4 GHz, so I hope she'll do well!
Happy Flying!
Ken
       Post #: 456
RE: New Hangar 9 B-25 - 9/23/2008 3:12:13 AM
modawg73
Status: offline
quote:
ORIGINAL: Charles_e_bates
Ok,
Look at my B-25 !!
Hey charles,
If you want you can turn around the carbs on your saitos and the needle valves will point up.
That's what I did. Also made the throttle linkages a little easier. I used flex cable to make it work.
Just thought I'd offer up what I did!
She looks sweet! What props are you planning on using?
Ken
       Post #: 457
RE: New Hangar 9 B-25 - 9/23/2008 3:17:33 AM
Charles_e_bates
Status: offline
Ken:
I like that, i'll check that out.
       Post #: 458
RE: New Hangar 9 B-25 - 9/23/2008 9:01:34 AM
raveon
Status: offline
Dear Ken
Thanks for your hints and tips about my b25.You say you are converting yours to 2.4 ghz you should not have any problems with that the conversion is easy.I just put one receiver under the centre tray and one on top,also used a 5cell sub c 6 volt nihm battery in the nose for balance and that was perfect.
Best regards Ray.
       Post #: 459
RE: New Hangar 9 B-25 - 9/25/2008 4:21:00 AM
modawg73
Status: offline
whooohooo!
Just got three solid flights tonight. Converted to 2.4 and was rock solid. It was easy like you said. No more hits or funny things going on. Not sure if that was my radio, or the combination of the airplane and twin engines.
Anyhow, she flew great, and I finally wasn't shaking when I was flying her. She flies great, lands smooth and easy, and looks incredibly scale like in her flying.
I just need to have confidence in my engines enough to turn the idles down so I can stop the plane before she runs off the runway!
Landed at half flaps. I'll try full flaps next time.
Ken
       Post #: 460
RE: New Hangar 9 B-25 - 9/25/2008 7:08:06 AM
BigGuyJT
Status: offline
quote:
ORIGINAL: modawg73
whooohooo!
Ken
Ken,
If you dont mind me asking, what radio set up are you using?
       Post #: 461
RE: New Hangar 9 B-25 - 9/25/2008 8:10:28 PM
modawg73
Status: offline
BigGuy,
I was using a Futaba 8uas with an 8 channel (I think it was a 148) futaba PPM (FM) receiver.
Then I switched to 2.4 Ghz by purchasing a Spektrum DSM2 Module to fit the 8u and a 9 channel DSM2 receiver. Still use the 8u, just broadcast on 2.4 spread spectrum.
(Btw, if anyone else does it that way, just watch out for how you wire the receiver. The first slot in the receiver is labeled "Throttle" which would correspond with channel 3 on the 8u. The second slot in the receiver is labeled "Aileron" which would correspond with channel 1 on the 8u. The third slot in the receiver is labeled "Elevator" which would correspond with channel 2 on the 8u. I called Horizon to ask them if the labels were correct (meaning that they had channel 3 in the first slot, channel 1 in the second, and channel 2 in the third.) They gave me the wrong answer on the phone. To work it correctly, you put the servos connected to the throttle in the spot labeled "Throttle" and so on.. apparently the module changes the channels when it broadcasts...kind of weird.)
I have two battery packs, 2400 mAh 5 cell NiMh, running through two heavy duty switches with a charge jack. They are mounted pretty close to the wing for balance sake.
Mounting the receiver, I put the main receiver on the space provided in the fuse just in front of the elevator servo, then I mounted the remote receiver in one of the holes next to the elevator servo. I glued on a small piece of plywood and attached the remote receiver such that it's antennas were pointing straight up and down (The yaw axis). So I have one antenna from the main receiver on the pitch axis, one from the main on the roll axis, and the two antennas on the remote receiver on the yaw axis. That way, the signal should always be received by at least two of them.
She flew rock solid on 2.4 Ghz.
On the FM, I always had some weird goings on. Nothing major, but I felt like I would take hits for a second at a time. It started when I was breaking in the engines on the ground. I did it in the bird, with the radio controlling the throttle. I would have weird noises coming from the bird intermittently. I wondered if it was being hit. One day at the field, I had the Tx turned on, the Rx turned on, and was trying to get one of the engines primed. I wasn't having luck, when all the sudden the tail waggled for a second, then stopped. 10 seconds later it did the same thing. After a third time, I shut it down. We looked for someone on my frequency (channel 29) and someone just started using channel 30, but that shouldn't be an issue.
The final time I flew it before switching, I felt like I lost control of her for a time. I guess i could have gotten disoriented, but it sure felt like it wasn't doing what I was asking her to do. On final approach, my engines revved up real high for about a half second without me doing that on the sticks. That was the last straw.
I am not sure if the issue is the twin aspect, or the routing of the antenna parallel and close to the elevator pushrod, or even a bad receiver. I pulled the receiver from a 1/4 scale cap 232 that I have flown for years, without ever having any similar issues, so I doubt it is that.
Whatever it was, the switch to 2.4 got rid of it.
Ken
(in reply to BigGuyJT)
       Post #: 462
RE: New Hangar 9 B-25 - 9/25/2008 10:44:11 PM
BigGuyJT
Status: offline
I did know that JR is different in the way the channels are sequenced on the reciever. I didnt know you could accutally run a Futaba tx and a JR rx. I'm glad it works for you. I have a Dx6i that I am planning on using til I can step up to a 7.
< Message edited by BigGuyJT -- 9/25/2008 11:22:11 PM >
       Post #: 463
RE: New Hangar 9 B-25 - 9/29/2008 11:49:30 PM
Charles_e_bates
Status: offline
More of my B-25 in work
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Charles_e_bates -- 9/29/2008 11:52:05 PM >
