kahloq
CO, USA Status: offline
bomb bay doors would be nice....except the battery hatch is located in that location. For those using fuel power, it might be possible to alter this and make doors. For those using electric....hmmmm. Will have to see once kits are in hand. As far as one motor going out on say a twin with smaller .52 or so 4strokes, well, if you hit LVC(low voltage cutoff) with electric motors...say the Power 46's, it'll be the same issue. Make sure you have ALOT of rudder available, but, generally, if a motor goes out on a twin, the idea is to shut down the other one(or briong it to idle) to prevent a yaw into spiral meets ground problem and land the plane quickly. I know people can fly on one engine, but reacting to one engine out fast enough can be problemtatic(if electric). On a fuel motor, usually there is some warning like weird noise...but not always. I've got a few twins(electric) and i have had a motor quit. This was on an A-10 where the two motors are quite close together. From the point that the one motor dropped, it took about 3 secs for instability to occur and yaw the plane over into a death spiral. If you can recognize whats happening in those 3 secs, you can save the plane. If not, kill the motor as soon as you realize whats going on and land straight ahead from where its pointing. Trying to bank and such to line up with runway with no power or only one engine on a twin and losing airspeed on a heavy plane is not a good situation. Hopefully, H9 has designed the B-25 to be a decent floater so power isnt critically required to effectively bring it in. My FSK B-25 does require a little power to land up until touchdown, but my P-38 can glide in with motors off.
