RE: New Hangar 9 B-25
Tower Hobbies
Logged in as Guest
  Printable Version
Mustang Exhaust - Kit
Seller:  tony-howard
Details:   $35.00   |  9/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Warbirds and Warplanes >> RE: New Hangar 9 B-25
Page: <<   < prev  7 8 [9] 10 11 12 13 14 15 16   next >   >>
Login
RE: New Hangar 9 B-25 - 10/25/2007 10:39:43 PM
CorsairJock
Status: offline
quote:
ORIGINAL: pettit
........................................I wonder if you can't just turn something around.
Nope: a right hand RoboStrut is a right hand RoboStrut, and a left hand one is a left hand one. Only way to get the wheel on the correct side would be to have the link/ scissors on the wrong side. That should be trailing/ on the back side.
Another reason for me to just purchase a set of Robart retracts and RoboStruts, NOT specicallyfor one of these B-25s. And like Isaid earlier: I can get them cheaper than the Horizon price of $320 (without air kit).
_____________________________
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
(in reply to pettit)
       Post #: 201
RE: New Hangar 9 B-25 - 10/26/2007 4:02:25 PM
JS615
Status: offline
i GOT MY B25 DONE AND TOOK IT OUT OF THE GARAGE ON TO THE DRIVE WAY UNDER THE SUN TO RUN UP THE ENGINES AND I NOTICED THAT THE ENGINE NACELLES AND COWLS DO NOT MATCH AT ALL I MEAN ITS LIKE NIGHT AND DAY, AND THE CANOPYS AND GUN TURRETS DONT MATCH ETHER,,,,, UNDER INCANDESENT LIGHT YOU DONT NOTICE IT MUCH AT ALL BUT OUT SIDE UNDER THE SUN ITS JUST BAD, IT LOOKS LIKE I PIECED TOGETHER A FRANKENSTIEN PLANE, NOTHING MATCHES, I CALLED HORIZON THIS MORNING AND THEY SAID THEY WOULD LOOK INTO THIS,, I JUST HOPE I HEAR SOMETHING BACK, THIS IS JUST NOT ACCEPTABLE, I PUT TO MUCH MONEY INTO THIS PLANE TO HAVE IT LOOK LIKE CRAP.......
HAS ANYONE ELSE NOTICED THIS,,,, MY PLANE ALSO CAME WITH THE ENGINES,,,,, IT WAS A GREAT DEAL UP TO THIS POINT AND NOW IM DISGUSTED....... HELP ME HORIZON PLEASE!!!!!!!!!!!!!!!
(in reply to CorsairJock)
       Post #: 202
RE: New Hangar 9 B-25 - 10/26/2007 10:44:48 PM
CorsairJock
Status: offline
The use of CapsLock is not only considered to be a form of shouting, and rude by some: it also makes it more difficult to read. Please calm down and turn off the CapsLock.
(in reply to JS615)
       Post #: 203
RE: New Hangar 9 B-25 - 10/27/2007 3:16:03 AM
scrambow
Status: offline
Sorry to hear about the color mis-match. I just did the initial inspection (inside under house lights) of one I am assembling. I hope I don't have the same color thing. I will take a look at them together outside tomorrow in the daylight.
Here's what I have right now: The engines came mounted with this one as well. Time saver some what. Both wings have broken sheeting and holes in the covering on the bottom just outboard of the aileron mount plates. The right wing leading edge is pretty beat up as well.
The kit came with two left vertical stabs and rudders, one of which has a hole in the rudder covering. The lower fuselage cover is too short by about an 1/8 of an inch length-wise. The nose section glass is cracked at one of the 90 deg corners. Other than this all looks well! LOL
Going to inform my LHS dealer and get some new parts coming. I plan on installing the spring down/air up Robart 737RS 90 deg main/105 deg nose set. The nose rails in the fuselage are wide enough; however, the main mount rails need some modifying in the nacelles.
I plan on removing the inboard support bulkhead and retract mount rail, moving it inboard 1/8 inch. The 730 series rails are 2 inches wide. This shouldn't be too difficult what with the way the Chinese use their glue.
       Post #: 204
RE: New Hangar 9 B-25 - 10/27/2007 9:34:45 AM
Jimmy Bananas
Status: offline
Corsair Jock:
In regards to decals for a Doolittle Raider, had mine doing by Callie-graphics.. ( KMP B-25) A very nice job she did for me...I just send to her the sheet of decals and she did them all,including the Doolittle Raider " The Ruptured Duck", design..Very reasonable on price...Picture of the plane is on her web site..Am sure she has them on file and why not ask her about them...maybe she can reduce them to fit your B-25...Give her a shout.
www.callie-graphics.com
good luck
       Post #: 205
RE: New Hangar 9 B-25 - 10/27/2007 9:47:08 AM
LDM
Status: offline
anyone doing a build thread with pictures ???
LDM
(in reply to Jimmy Bananas)
       Post #: 206
RE: New Hangar 9 B-25 - 10/27/2007 1:04:49 PM
John Redman
Status: offline
This is really odd to hear about the color mis-match. We never saw this on any of our prototypes. I will say the color mismatch on the Top Flite is just as you describe though.Not saying anything bad here, just what I have observed when I was flying with Greg Hahn at the DOGS show.
Can you post a picture of the mismatch so we can see? I would be interested to see how bad it is. ANyone else have a problem here? If so a few pictures and we will work the issue.
< Message edited by John Redman -- 10/27/2007 1:06:02 PM >
John Redman; Team JR, BVM Rep, JetCat USA Rep, Horizon Hobby/E-flite Product Developer/Manager
(in reply to LDM)
       Post #: 207
RE: New Hangar 9 B-25 - 10/27/2007 1:23:47 PM
LDM
Status: offline
There always spay paint , weathering and all the fun things that make it my own !!!!
Does Horizon sell the paint to match the covering ???
LDM
(in reply to John Redman)
       Post #: 208
RE: New Hangar 9 B-25 - 10/27/2007 2:45:12 PM
John Redman
Status: offline
Unfortunately we do not. There is no paint available from Horizon Hobby in a spray can that matches Ultracote.
Tony Stilman at Radio South will custom mix PPG paints for you to match I do believe.
(in reply to LDM)
       Post #: 209
RE: New Hangar 9 B-25 - 10/27/2007 4:28:59 PM
wildswan
Status: offline
John,
Do you know when the UK will receive it's first B-25's?
Jason
       Post #: 210
RE: New Hangar 9 B-25 - 10/27/2007 5:37:02 PM
bbrundle
Status: offline
The first shipmewnt of B-25's to the UK will be in December.
Bill Brundle
Senior Product Developer Hangar 9, Saito, & Evolution
(in reply to wildswan)
       Post #: 211
RE: New Hangar 9 B-25 - 10/29/2007 3:47:03 AM
JS615
Status: offline
Well i took my b25 to the field yesterday and showed all the pilots there and they all noticed the differance in color, one of the other members brought one of his wings and a engine necelles and it was the same way..
At noon yesterday under direct sunlight you could see the differance, but most of the guys there said they thought it was ok, and theres probly nothing anyone could do about it!
and that the color was as close as its going to be,,,,,, i exspected the colors to be exact but i guess i will have to live with it!!!!!!!!
I did get to maiden it though,, i flew it 4 times, I can say that it flew like a charm, very easy plane to fly and the evo 36 engines are plenty of power,,,,, but after carefull inspection today as i cleaned up my b25 from the flying yesterday, i noticed stress cracks in the fiberglass necelles, on the bottom right behind the firewall, and at the back on top
right behind where the necelle bolts to the wing,, dont know whats going on but i hope it does not get any worse,,,,, there is very little vibration that i could feel on the plane, and the props are balenced perfectly,,, i guess time will tell......?
(in reply to bbrundle)
       Post #: 212
RE: New Hangar 9 B-25 - 10/29/2007 3:51:27 AM
CorsairJock
Status: offline
Very rarely do colors of covering and paint have an exact match. As for the cracks: please keep us posted.
(in reply to JS615)
       Post #: 213
RE: New Hangar 9 B-25 - 10/29/2007 3:58:50 AM
JS615
Status: offline
Yes i will keep everone informed, i was pretty shocked when i saw it,,,, the crack is where the first former is just behind the fiberglass firewall,,, i will say that its not a bad idea to reinforce every where inside the engine necelles!
