Prop for OS 46 AX
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> Prop for OS 46 AX
Page: [1] 2   next >   >>
Login
Prop for OS 46 AX - 6/29/2007 5:14:49 AM
mesaflyer
Status: offline
I posted this message at the end of another thread, but did not get any response, so I thought I would try it again. I have a prop question. I have an OS 46 AX engine on my H-9 Pulse XT. The engine manual recommends a 11 x 6 for break-in. After that, the manual says I can run a 10.5 x 6, 11 x 6-8, or 12 x 6-7. I don't need to have the fastest plane, but curious if anybody out there has any experinece trying different props and what seemed to work the best for this plane or engine.
       Post #: 1
RE: Prop for OS 46 AX - 6/29/2007 5:24:59 AM
Major Pain
Status: offline
mesaflyer: My buddy has a Pulse XT with OS 46 and has good luck with 10x6. I've flew it and it has plenty of power and get up and go. Kinda depends on the kind of flying you do but good alround prop.---------Revver Bro#164
(in reply to mesaflyer)
       Post #: 2
RE: Prop for OS 46 AX - 6/29/2007 5:38:33 AM
ServoShack
Status: offline
I was asking about the engine and someone said a MAS Master Air Screw 11x7. Well they said it's good for beginners (me)
(in reply to Major Pain)
       Post #: 3
RE: Prop for OS 46 AX - 6/29/2007 11:18:33 AM
j.duncker
Status: offline
11x7 will be running below the peak power point. It will be quieter though.
11x5 or 10.5 x 6 seems to be the sweet spot for this engine.
_____________________________
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
(in reply to ServoShack)
       Post #: 4
RE: Prop for OS 46 AX - 6/29/2007 1:35:01 PM
hungryandbroke
Status: offline
I have the OS 46 AX on my sig something extra and I run a 11-6 prop on it.
I beleive the smaller size props will make it faster once it's in the air and the larger size props will give you less speed but better pulling power.
On take offs smaller props = longer runway to get it airborne.
Larger props = shorter runway to lift off.
I beleive the more rpm's you get out of an engine = more wear on your engine.
Experiment with different props and then you will know.
If I had the pulse I'd run a 11-6 on it with the os 46 ax.
I learned one thing in this world. It's not how much you make, but how you spend it!
(in reply to j.duncker)
       Post #: 5
RE: Prop for OS 46 AX - 6/29/2007 1:56:15 PM
da Rock
Status: offline
11x5 has been ok on all those engines at our field. A number of fliers have had better luck with 11x6s.
10x6 used to be the accepted standard for 35s. All the guys who've run them at our field on the 46AX have changed to larger props . Well, one guy still is running a 10x6 but he loves speed and screaming engines. I've tried to talk him into trying a 10x7 or 10x8 but he hasn't so far.
(in reply to hungryandbroke)
       Post #: 6
RE: Prop for OS 46 AX - 6/29/2007 2:35:56 PM
CGRetired
Status: offline
You can find a range of props for that engine. It all depends on what performance you want. Smaller pitch props (the second number in the prop size) will usually cause more RPM. So, you will have to watch that so you do not exceed the max RPM for your engine. It is not unusual to get 12,000 RPM out of that engine when it is running correctly and correctly prop'ed.
Think of the pitch as changing gears in your car transmission. Lower gears relate to lower pitch numbers. You get more power, faster acceleration, higher RPM, but less speed. Higher pitched props will give you less power, slower acceleration, lower RPM, but higher speed. But, at limits. You cannot, for instance put a 15-10 prop on a 46 sized engine. It will run, but you will never get the thing off the ground.
Click to see fullsize image.
Click for fullsize
< Message edited by CGRetired -- 6/29/2007 2:37:35 PM >
Skylark 70 - OS 75 AX; Venus II - OS 1.20 AX; Tiger 120 - OS 1.20 AX; Protege - OS .75 AX. Airtronics - Spektrum. AMA 705964. Semper Paratus!
(in reply to da Rock)
       Post #: 7
RE: Prop for OS 46 AX - 6/29/2007 8:53:23 PM
fadi81
Status: offline
I used to run my OS 46AX at 13600rpm with the 10x6... I killed the engine after a while
Note that in the catalog they specify a theoretical range up to 17000rpm with a power peak at 16000rpm (never happens in real life)
I bought another one, installed the 11x5 and 11x6 and event went up to the 11x7 then 11x8; and finally tried the 12x4 on 3D planes
They all run differently, but I feel you get the best out of this engine with the 11x5, 11x6 and 12x4. It depends on what you need.
After all, the manufacturer, for breakin, I think, should be recommending the ideal prop in its manuals
As we think so we become
(in reply to CGRetired)
       Post #: 8
RE: Prop for OS 46 AX - 6/29/2007 10:06:52 PM
jaka
Status: offline
Hi!
What's an ideal prop??
Jan Karlsson Airracing products
MVVS, Motul "Micro" all synthetic oil
(in reply to fadi81)
       Post #: 9
RE: Prop for OS 46 AX - 6/29/2007 11:00:11 PM
hungryandbroke
Status: offline
The one that won't bite your fingers!
(in reply to jaka)
       Post #: 10
RE: Prop for OS 46 AX - 6/29/2007 11:07:47 PM
KIreson
Status: offline
Using a 10 X 7 prop with the AX46 is the answer for performance. It puts the engine in the power range for max power without over reving.
       Post #: 11
RE: Prop for OS 46 AX - 6/30/2007 2:06:34 AM
fadi81
Status: offline
Yeah I know you are right, the ideal prop depends on what you want to achieve but in the contest of our conversation, I meant the prop that puts the engine in its comfort zone and achieve good power output in relation to its fuel input and/or weight...
(in reply to jaka)
       Post #: 12
RE: Prop for OS 46 AX - 6/30/2007 2:59:38 AM
Enterprise7
Status: offline
what the rc world needs is a nitro size variable pitch prop. I have the rimfire v-pitch on my flatout but haven't flown it yet.
Another happy landing.
       Post #: 13
RE: Prop for OS 46 AX - 6/30/2007 5:33:37 AM
JPGale
Status: offline
quote:
ORIGINAL: fadi81
I use the 46AX on my race T34's and I run 9.5x6 APC at upto 17200, 9.5x7 Bolly at 15000 and 10x5 APC at 16500, the fast one is the bolly, the engines in these planes have been know to last for 2 or 3 years, or 1 year and then make a great sport engine. We run them at the limit, but I know one of the guys put a 46AX on a skyraider mk2, to make sure he did not rip that plane open he used a 12x4N, he says it is real slow but great pulling power, for a beginner that would be the best way to go big low pitch prop. Also get some good after run oil, I use http://myrcsupply.net/index.php?main_page=product_info&cPath=100_113&products_id=42204&zenid=8eef40ab407bc8ae93ed377e446ebc17 and it is great it will look after the engine well if you take the higher RPM option.
Also in another post this engine on a small prop my plane will take off across the runway at my field with is about 65ft.
James Gale - Team Norred Aero Products #78 www.t34racing.com
       Post #: 14
RE: Prop for OS 46 AX - 7/1/2007 6:14:30 PM
DocWill
